Sport exhaust problem
Recently had a problem with actuation of sport exhaust on 991 C2S.
It seems to be stuck "mid-way" neither fully open or fully closed. With the engine off and ignition on, and switching either the exhaust button or Sport button on and off, I can hear mechanical actuation beneath the car so it's not an electrical problem. However, the exhaust note does not change with either switch and it sounds not quite fully closed or fully open.
Any ideas, thoughts, comments?
Pretty sure one of the vacuum hoses on your exhaust system came off. Soon your screen will show "cooling system error". For some reason Porsche really dropped the ball in this design. Hoses made just the right length, but actually too short because they tend to shrink with heat along with mickey mouse weak rubber hose connections causing the vacuum hoses to easily come off. Mine has come off in different spots so many times that I know how to reconnect them all myself. But I have to go back to dealer each time to reset the error code. In fact have to do again either today or tomorrow because the one at left the exhaust valve under the car came off last night and the error came on my screen. 4th time in 2 months. Thumbs down for porsche on this poor engineering!!!! Blah!!!
+1 on a great point that is not limited to these hoses, some of Porsche's wiring seems awfully tight as well, I mean which bean counter determined that an extra eighth of an inch would break the bank?
Would explain why exhaust sounds loud even though switched off. Obviously will get dealer to check.
I would like to get a better understanding of how exactly PSE works. Probably already been posted somewhere here.
I have a slightly used fabspeed center muffler bypass xpipe available in Toronto. Pls pm me for details/price.
Let's say you had a base 3.4L engine and installed a 3.8L S muffler. Does the 3.4L engine have a place for the vacuum lines to attached to? Ie could you get the valves to work in that config.
Sent from my iPhone using Rennlist
