Using the slime to fix a flat
I recently hit an object in the road and cut the tire sidewall. This happened in a remote area with no cell service. I also bent the wheel.
Proceeded to repair the flat with the supplied slime. It took several stops to refill the tire with air, but was able to limp home. I was lucky.
If the cut were any bigger, I'm afraid that I would have been stuck.
I am now also carrying a few rubber repair "ropes" to try to repair a larger cut. Thought it might work with the slime to stop the leak.
Does anyone have any tips for repairing a tire in this situation?
Thanks.
PS: The tire and wheel insurance that I bought with the car has paid for itself.
Thanks.
Sorry to hear.
And thanks for reporting about using the slime.
Every time I open the frunk I look at that kit and ask myself... when?
If the damage is on the sidewall most likely they won't attempt a repair. At least most of the tire shops around here won't. Too much liability. Some won't even repair a tire any longer even if the puncture is in the middle of the tread. They just want to sell a new one.
Hope they can repair the wheel. They can do wonders these days.
I suggest that everyone should carry a plug kit and know how to use it. It will temporarily fix anything short of a catastrophic blowout or sidewall tear. The slime won't damage the rim, but it will make a huge mess that the tire shop is going to be loathe to have to clean up.
A plug kit and the onboard pump should get you mobile to more permanent help 90% of the time if you're somewhere where waiting is a hassle.
I recently had a very slow leak, so small that at first the dealer couldn't find it when my car was in for a service. It was a new tyre and was loosing about 5 or 6 psi a week. I used the fix a flat product and have not had any issues. Back in my motorcycle racing days we used to use the product not to fix a flat, but to balance a wheel with a new tyre if we were in a rush. It took a lap or two for the stuff to circulate but after that the wheel was balanced.
Used it in the tires of my mountain bike to prevent a flat.
If my car were to have a flat, I'd call for a flat bed truck. No screwing around with the rims, tires or the extended warranty i purchased for both.
I wish they still had spare tires, but nobody asked me...
A plug kit is a great idea. Even if you have a spare it's easier than changing a tire. I have one in every car and on my motorcycle.
