Nitrogen
Old Oct 18, 2013 | 08:22 PM
Bacura's Avatar
Bacura
Default Nitrogen
My dealer now puts in nitrogen in all its cars. I know there is no downside except that I can't use air at the gas station. Theoretical advantages include less leakage due to nitrogen being a larger molecule. Also, less flamable since nitrogen doesn't support combusion. And finally, less water vapor. All of questionable benefit since air is 80% nitrogen anyway. My question is, does anyone have any real world experience either positive or negative. My gut feeling is that it's BS.
Old Oct 18, 2013 | 08:33 PM
LexVan's Avatar
LexVan
Ask for helium next time to reduce unsprung weight. And cheaper than nitrogen. Car might squeak a little.
Old Oct 18, 2013 | 08:38 PM
JamesKen's Avatar
JamesKen
My dealer does the same and it is better but you will never notice. When you say you can't put in air at the gas station I would say you can or that nothing bad will happen if you mix the nitrogen with regular air. You will just lose some of the benefit. I have also heard you have less of a problem with air pressure with big swings in air temperature and less of a problem at the track when the tires heat up. I don't know if either of these things are true.
Old Oct 18, 2013 | 08:44 PM
LexVan's Avatar
LexVan
This was all just covered last week, again, on the 997 Forum. The key is that you want dry air. Less moisture, yields a steadier tire pressure over a changing temperature gradient. All gases adhere to The Law Of Gases.
Old Oct 18, 2013 | 08:46 PM
meine911's Avatar
meine911
Less leakage and cooler are the main attributes. I don't think it's BS, but is it worth the hassle to find a nitrogen pump? Not for me.
Old Oct 18, 2013 | 08:51 PM
JamesKen's Avatar
JamesKen
http://www.tirerack.com/tires/tirete...jsp?techid=191
Old Oct 18, 2013 | 09:19 PM
chuck911's Avatar
chuck911
Lexvan nailed it. Using nitrogen is better not because nitrogen is better (air is already 80% N) but because it comes out of a bottle with no water vapor. In a way its a shame. I really like the squeaky car answer.
Old Oct 18, 2013 | 09:36 PM
Larson E. Rapp's Avatar
Larson E. Rapp
I wonder how long a helium-filled tire would stay inflated. Probably not more than a few days at most...
Old Oct 21, 2013 | 04:14 PM
fantom's Avatar
fantom
Sure you can, without issues. Slower leakage about the only benefit.
Old Oct 21, 2013 | 04:37 PM
CarManDSL's Avatar
CarManDSL
Veteran: Canadian Forces
When I bought my 991S in June '12, the dealer had inflated the tires with N during PDI. They asked for $200.00!!
I laughed and didn't pay.
Old Oct 21, 2013 | 06:35 PM
JamesKen's Avatar
JamesKen
Wow, I wonder how many people would pay that.
Old Oct 21, 2013 | 07:08 PM
chuck911's Avatar
chuck911
Lotta people don't know the air we breathe is 80% nitrogen. Scientific illiteracy, donthca know? I mean, look how many bought into the manmade global warming swindle. CO2, a trace element measured in ppm, is magically transformed into a world-destroyer simply by waving around the pseudo-scientific phrase "greenhouse gas". In order to believe this you had to not know what a greenhouse gas really is, that water vapor is the #1 greenhouse gas, that CO2 is only a small part of greenhouse gases, that termites, trees, volcanoes, cows and plankton - each- all make more greenhouse gases than man, and that solar output accounts for 90+% of temperature variation anyway. Man that is a LOT of scientific ignorance- and yet vast populations bought into it. That dealer is probably making money hand over fist. Bet he does the same deal on a Prius, tells them its saving the planet and they pay $400!
Old Oct 21, 2013 | 09:20 PM
meine911's Avatar
meine911
"Like" button pushed.
Old Oct 21, 2013 | 09:23 PM
TheDatanator's Avatar
TheDatanator
When I bought my 991S in June '12, the dealer had inflated the tires with N during PDI. They asked for $200.00!! I laughed and didn't pay.
Mine did the same but tried to poke me for $85. I closed my checkbook and laughed. They zeroed out that line item pronto.
Old Oct 21, 2013 | 09:30 PM
JohnnyBahamas's Avatar
JohnnyBahamas
So, Prius owners who REALLY care about the planet should demand that their tires be filled with water vapor.
