sport exhaust enhancements
Old 10-05-2013, 06:25 AM
rnl
rnl's Avatar
Originally Posted by DvidzBlk991
Does this include a 991 C2 with no PSE? Does a C2 with the regular exhaust still have a sound symposer activated with Sport ? I dont have Sports Chrono.
Yes
Sent from my iPhone using Rennlist
Old 10-05-2013, 11:11 AM
chuckbdc
chuckbdc's Avatar
Originally Posted by kosmo
Why do you have pse?
I find PSE sounds are sweet all the time. The intake sounds from the symposer on the other hand are great going up the scale, but at constant speed, especially in higher gears, not so much. It is a pale imitation of the old 911 intake symphony.
Old 10-05-2013, 02:59 PM
mtony
mtony's Avatar
Yes, I have PSE and would rather hear the exhaust than the moaning sound from the intake/engine.
Old 10-05-2013, 03:15 PM
lbahoshy
lbahoshy's Avatar
Originally Posted by mtony
It's located under the rear deck. If I remember correctly the deck just comes out with a pull. You will then see a strip of insulation lengthwise under the deck. Pull the insulation out and you will see a small round opening. That's the end of the symposer. I stuffed some insulation into the tube and added some more under the stock insulation under the deck.
Just press the "exhaust" button and not the "sport" button. This will activate the PSE only and not the sound symposer
Old 10-05-2013, 04:26 PM
mtony
mtony's Avatar
I also have PDK and like how the Sport setting changes the character of the shifts.
Old 10-06-2013, 02:46 AM
ArashApollo
ArashApollo's Avatar
Speaking of which, for those who want more engine sound, is there a way to get more sound into the cabin somehow from the symposer ? (Removing any insulation) ?
Yes! Pull off the cover thing (the part touching the bottom of the rear glass) and remove the insulation. Heck you can even leave the cover off too. It makes a HUGE difference.
Old 10-06-2013, 04:32 AM
lbahoshy
lbahoshy's Avatar
Interesting! Have you done this in your car?
Is this cover easily removable without damaging anything?
Old 10-06-2013, 01:58 PM
Viper3838
Viper3838's Avatar
Here is a link on youtube of the inside look of a 991 which briefly describes the actual sound symposer
Old 10-06-2013, 05:19 PM
mtony
mtony's Avatar
Yes, the cover just pulls up and off with a yank once you get your fingers behind one side of it. Nothing to mess up and it will just snap back into place.
Old 10-07-2013, 09:28 AM
Viper3838
Viper3838's Avatar
Thx for the tip. Did it yesterday but instead of removing the insulation, I pushed the insulation away from the sound symposer opening to let more sound into the car. Sounds great with sport depressed! Super thanks!
Old 10-07-2013, 09:59 AM
extanker
extanker's Avatar
cant say anything about the sym but it seems the poser applies
Old 10-07-2013, 11:26 PM
lbahoshy
lbahoshy's Avatar
Thanks! Will have to wait till I get my car to have a look ( it's going into production this Friday!)
Is the symposer visible without lifting the rear shelf cover?
Old 10-08-2013, 04:59 PM
Viper3838
Viper3838's Avatar
you will have to remove the cover. just pull it towards yourself with 2 hands while you are facing the back window. it pops out easily (i think there are 7 clips in total). you will see insulation once the cover has been removed. Pullout the insulation. slightly right of centre on the bottom, you will feel a hole which is it (hard to see because the glass is in the way) .
Old 10-12-2013, 10:39 PM
cmb13
cmb13's Avatar
I wonder if the symposer can be turned on all the time, for instance reprogrammed to stay open. I don't want to remove insulation as I would think the interior might get hotter from the engine compartment, and I'm in South Florida.
Old 10-15-2013, 01:04 AM
lbahoshy
lbahoshy's Avatar
Thanks for the tip
Quick Reply: sport exhaust enhancements
