'washing' with WD40
'washing' with WD40
So, due to an unfortunate incident, my car ended up with a splash of tar all along one side below the door-line. I didn't spot it for a couple of days due to inclement weather by which time it was pretty well set.
After washing with concentrated liquid and trying a clay-bar I had hardly made any progress in removing the tar. A mate of mine said; "Spray WD40 on, leave it for ten minutes and then it'll just wipe off."
Yeah, right, as if.........
Well, I did just that (with a huge amount of scepticism, I must add). I was astonished at just how effective this stuff was. The tar just wiped clean and then I washed off the residue.
Which brings me to the topic: what I also noticed is that the area I had sprayed/wiped/washed was immaculate - at least as good as after a clay-bar session, perhaps better. And unbelievably easy to achieve. I imagine that WD40 is pretty neutral on our cars' paint (well, after two days now there is no apparent sign of anything) so I wonder if anyone here has had a similar experience and, more importantly, has anyone actually been brave enough to spray THE WHOLE CAR and admire the results?
Just asking.
nb: I absolutely hold no brief in any way for this product!
Just asking.
Received 5,416 Likes
All the track guys know this trick.
You probably need to re-wax those areas, too. FYI. I would not try this on any clear bra, untill color tested. Not good for your stone guards either.
The only way to correct the paint and remove light scratches is with the proper polish and orbital polisher. A drum of WD-40 won't do I thing.
yes I've used wd40 and other penetrants. It does remove Tar, gunk, and tire marks. I usually follow it w/ a spot wash using Dawn and then reapply a thin wax coat.
3M adhesive remover works even better. Don't put it on stone guards, decals or plastic films.
I've used WD40 to remove adhesives and tar before. It contains a solvent similar to turpentine, which is why it dissolves stuff like tar, but also contains mineral oil which is why I wouldn't spray it all over my car as the OP asked about.
Stoners makes a product designed to remove bugs, sap, and tar called Tarminator. In addition to not containing any oil or other lubricants it's also more cost effective to use. (No affiliation just a satisfied customer)
www.tarminator.com/
www.tarminator.com/
www.tarminator.com/
www.tarminator.com/
Thanks, Mike.
Ive used Einszett and CHemical guys Bug n tar remover. E is more money than C and they work about the same.
MIke, you sure youre not affiliated w/ Stoners? We know you live in California!
The key to these products are whether they are Ph Balanced and whether they will remove wax.
Anything that removes winter grit and grime without scratching like a clay bar is a win.
