Is break-in or run-in really required?
#46
#47
Was told by porshe dealsr that the reason why Porsche and other manufacturers ropagate the myth that cars need to be "broken in" is to avoid new drivers pushing the car too hard before they are familiar with it. Has nothing to do with the actual engine.
#48
Breaking in an engine has some remarkable similarities to taking a woman's virginity. Think about the analogies for a minute ! And then decide which way is the way to go !
#49
I just returned home from European Delivery, which provides for the ultimate break-in!
At delivery, I was instructed to keep the revs under 5000. I did keep the revs under 5000 the entire trip, save for once. I was driving in the left lane when I saw that the lane was ending soon. There was a line of cars to my right. I floored it and reached 6000 rpm, in order to find a spot to pull over.
Other than that, no full throttle take-offs from stopped. Varied RPMs constantly. Never lugged the engine. I did experience many full throttle accelerations in 4th and 5th gears. When will I ever be able to do that again??? I fully intend to have a freely revving car!
I'm very happy and comfortable with my break-in. Already 1700 miles done!!!
Kevin
Kevin
#52
#53
My dealer told me to forget about the break-in period and "enjoy" the car from day one. I drive such low annual milage (The C2S is my DD) that keeping a high-end torque car under 4000rpm for 2000 miles would of made me go insane!
#54
My dealer also told me to forget the break-in and drive the car hard from day 1. He said with all of the dyno testing these cars are put through in production, at the time the car is delivered the engine is either broken in or it would have broken down!
#56
absolutely horrific analogy.
#57
Only one flaw in that rationale. There's no dyno testing.
#58
You really believe there is no extra wear and tear at high rpm ?
#59
But what actually happens is hydraulic forces (aka, lubrication) prevents this contact. "Wear and tear", in the sense most people think of it, happens not when you floor it but when you first start it up. Those few moments after starting and before oil pressure comes up account for virtually all the "wear and tear" over an engines lifetime.
But what about high RPM? Still no contact, therefore no "wear and tear". But, lots more physical stresses on all the parts. Its the repetition of these high stress cycles that can cause parts to fail. Its obvious when parts break. But they don't always break. Stress cycles can also result in parts merely going out of spec- and out of spec parts can result in contact, and wear and tear, eventually failure.
And so: when is it safest to use max output and RPM's? When the engine is fully in spec. And when is an engine most likely to be fully in spec? When its brand new.
#60
