A month owning a 991 C2S
I don't agree with that notion. The "half key hanging out of the dash" is a bit weird for starting, but it works as well as a button. The comfort of the keyless entry for me is NOT having to dig my keys out for getting into the car. Whether it's pushing a button or turning a "key", doesn't matter. Both are fire and forget, you twist/push it and it goes. Key stays in pocket.
Received 5,404 Likes
The keyless entry system is also very easy to lock by just touching the handle.
I HATE the start/stop function. I gives you the feeling you're driving a Prius. I keep the sport plus on all the time partially to eliminate the start/stop and because I love the firm ride from all those expensive suspension components I paid for.
Additionally with start/stop, my radar detector (which is hard wired) dies when the function is on. I also noticed a minute hesitation when you press down on the throttle to get moving again.
I love the keyless entry.
Only on highway cruising I put my car in comfort and D, and let the start/stop do the sailing.
Do you have detailed info on that (piwis code ?) so I can go to my dealer with that info to have that sorted ? Would be sooooooooo nice.
Unfortunately, I understand this is not possible for European cars.
In order to achieve their stated EU consumption/CO2 figures it needs to be set as a default 'on' feature at all times and can only be selected as off. USA and elsewhere it's the other way around.
I was afraid something like this was the case. Damn Euro legislation.
Smithr, I did a similar thing. While considering a porsche 2 years ago, I decided to get a used 135i. I then proceeded to Dinan tune it to 378 hp, 400lb/ft. what a blast to drive.
I continued to test drive the 911, and fell in love with the 991.It's a completely different experience to me.
Isn't that the opposite of what you should feel when driving a 911?..
When I start the car im planning to hit the start/stop botton everytime or Ill just press the Sport button to avoid the engine start/up. Ill gladly take the possible 1 mpg hit anytime to not have that system active.
2014 C2 on order
