Chassis System Failure Warning
Old Sep 12, 2013 | 09:32 AM
LDs2010V's Avatar
LDs2010V
7th Gear
Default Chassis System Failure Warning
Has anyone received this warning? Happened last week in my 2012 991S and it was followed by a screeching/whining noise around the right rear wheel. Dealer has not determined the problem.
Old Sep 12, 2013 | 02:51 PM
CarManDSL's Avatar
CarManDSL
Veteran: Canadian Forces
Your timing is impeccable!
Just yesterday on a lonely deserted road I had it up to 220 km/h then immediately braked to get it down to 150km/h. Upon braking, there was a loud whining sound coming from the right rear. This lasted from 220 down to about 150 when I let off the brakes and let the car coast down to 100. No warning lights. Had the sunroof tilted up so the sound was very loud.
Never occurred before doing the exact same thing on the same road, several times over the last year.
May 2012 build, 991S.
I will jack up the car and inspect the right rear ASAP!
Old Sep 13, 2013 | 05:52 AM
Rainier_991's Avatar
Rainier_991
Small rock thrown up by the braking action jamming between rotor and some brake assembly part can do that.
Had one even worse - small rock of just the right size got between the rotor fins and jammed a front completely solid (happened at very low speed). Took a lot of jigling to finally break the rock and free the wheel.
Rainier
Old Sep 13, 2013 | 09:20 AM
Riz's Avatar
Riz
Just curious - do you guys have PDCC?
Old Sep 13, 2013 | 01:53 PM
CarManDSL's Avatar
CarManDSL
Yes.
2012 991S, Sport PASM, S Chrono, PDCC
Didn't think of the jammed small rock that Rainier pointed out. Didn't find anything out of place when I inspected and issue has not happened again.
