GT3 Steering Calibration for 991 base and S
^^ +1 ^^
I think that when it was stated that the EPS hardware was identical, that just means that the specific part is the same (steering column, steering motor??). The GT3 has a bunch of differences in the entire suspension set up, so as much as I'd like it to be the case, I don't think the GT3 steering calibration will translate to a regular Carrera. Not that it was bad to begin with IMO.
Standard features from uk website,
GT3
Rear axle steering with sports tuning
Electromechanical power steering with variable steering ratio and speed-sensitive power steering assistance
Dynamic engine mount system
McPherson spring strut axle, front anti-roll bar, chassis bearings partially with ball joints
Multi-link rear axle, rear anti-roll bar, chassis bearings partially with ball joints
Porsche Active Suspension Management (PASM) adjustable damper system with sports tuning and lowering of approx. 30mm compared to the 911 Carrera
Porsche Stability Management (PSM) with ABS, ASR, ABD, and MSR 2-stage switching strategy for deactivation
Adjustable chassis for race track use (toe, camber, anti-roll bars)
Turbo
Rear-axle steering
Porsche Stability Management (PSM) with ABS, ASR, ABD, MSR
McPherson-strut suspension with anti-roll bar at front
Multi-link suspension with anti-roll bar at rear
Regular Carreras
Power-assisted steering with variable steering ratio
LSA multi-link suspension with anti-roll bar at rear
Enhanced Porsche Stability Management (PSM) with ABS, ASR, ABD, MSR and additional brake functions
Porsche Active Suspension Management (PASM) with ride height lowered by 10 mm
GT3
Turbo
Rear-axle steering
Regular Carreras
Ah, so inconsistent writing is what's throwing you.
USA site:
"Electromechanical power steering with variable steering ratio and steering impulse "
And if you add Power Steering Plus the speed sensitive bit, too.
USA site:
This is typical of many product marketing spiels.
Even though all the various models in a product line have all the same base features, the marketer will describe them differently or highlight more of the same specs in the upper model so that you think you are getting a lot more than the lesser model.
In pyramids quote from the UK site, this is classic deception!
Really recommend doing this.
Hope that helps.
Looking for some clarity - is in fact the Power Steering Plus $270 option on my 2013 Carrera S the same as the GT3's "Electromechanical power steering with variable steering ratio and speed-sensitive power steering assistance" ?
I just order a set of KW V3 Coilovers, I think it should help bring some steering feel back, from all the feedback I read online with just lowering the car with H&R springs. With a completely new suspension it should help transform the handling quite a bit, will give feedback after installation
That is what I would like to know. Is it better to order the Power Steering Plus option just in case it is the one similar to GT3 steering just with different software programming?
BTW the Carrera models also have electromechanical variable ratio power steering and I always thought it was speed sensitive as well.
The steering unit itself in the Carrera and GT3 is the same except for the software programming. But some of the difference in steering feel is due to the wider track and different tires, springs and shocks, lower control arms, and suspension settings of the GT3. That's why I don't think the GT3 steering software would work properly on the Carrera; it would have to be recalibrated for the differences of the Carrera chassis.
Supposedly, nearly every suspension piece on the GT3 is revised from the Carrera so despite the Anniversary car having the same wide track chassis there are still many differences. I'm sure the steering software on the GT3 is also programmed to work with rear wheel steering on the GT3 which the Carreras don't have.
Not saying I know it wouldn't work, just that there are reasons why it might not.
