changing dial faces
changing dial faces
I'm considering changing the instrument dial faces on my 991. Anyone know how big a job it is to do that? Is the instrument pod readily removable or does the whole dash have to come apart?
Did you get any answer? My MY 2013 991 C2S has black dials and I was told by the parts department of my Porsche dealership that the whole instrument panel must be changed at a cost of $5600. Of course the dials would be OEM parts and not after market. Any information would be helpful.
Anyway, the instrument pod is readily removable and no dashboard removal.
Short version,
- remove steering wheel.
- remove plastic cover behind steering wheel.
- pull out straight the plastic surrounding cover (between instrument and dash).
- unscrew instrument unit, take them out.
- pull out odometer button.
- unclip some tabs to remove the clear plastic cover.
- now everything are exposed.
If you need further info, I'll type from my laptop .
There is not an insignificant difference between (1) changing dial faces and (2) swapping out the entire instrument gauge cluster.
For the former, you can buy different dial color faces from Rhonda at FVD (or Suncoast). These are aftermarket parts, and not OEM. From speaking with Rhonda, the swap of just the dial faces (not the entire gauge cluster), requires some sort of special tool that not all tuner shops have. So if you want to do this, before you order, you should call around and make sure there is a local shop that has the necessary equipment, or ask Rhonda at FVD for a referral. (As for DIY, I don't think so, but I am as handy with tools as I am with an unpinned grenade. In other words, not very.)
For the latter, if you want to switch out the entire cluster gauge, then you just need to buy the different cluster and it's generally plug-and-play.
Good luck.
Received 4,187 Likes
I'd be very interested in a step-though on anyone who has done this themselves, with instructions. I've no interest in paying someone to do it and can work on the car easily myself. I find the black gauges, especially the Gray Tach on the "S" models, to be nearly illegible with sunglasses on and would switch to white faces if the job isn't too involved or requires major dash dismantlement. TIA
I think one needs to be careful in what is being asked.
Good luck.
Good luck.
If you want to replace the gauge face there are other option than just swapping out the perfectly good gauges for new ones.
You can get an FVD upgrade kit at Suncoast (and I'm sure others) for $765 that upgrades the gauge face of the main instruments. and another that does the Sports Chrono for $329. So basically for about a $1000 you can upgrade them all.
http://www.suncoastparts.com/product...iorAccessories
They aren't Porsche parts but are from FVD. I've seen the results and I can't tell the difference between the factory and FVDs.
Nope... If you want to replace the gauge face there are other option than just swapping out the perfectly good gauges for new ones. You can get an FVD upgrade kit at Suncoast (and I'm sure others) for $765 that upgrades the gauge face of the main instruments. and another that does the Sports Chrono for $329. So basically for about a $1000 you can upgrade them all. http://www.suncoastparts.com/product...iorAccessories They aren't Porsche parts but are from FVD. I've seen the results and I can't tell the difference between the factory and FVDs.
Funny thing is Porsche does have repair kits for things. For example the center console buttons have a repair kit at a somewhat reasonable cost.. So go figure.
