Real world experience with Carerra S Powerkit?
#91
Jack, I got 5% off on a custom order for my 2014 C4S with X51 and a bunch of other stuff.
https://rennlist.com/forums/991/7568...uild-info.html
Might have been able to get more if I pressed...
#92
The Torque on a 991S with X51 is essentially the same as normal S engine. HP is up but not torque. However, the torque curve is very much smoothed out above 6000 RPM though.
#95
I wanted a "low key" appearance car without spoiler. The turbo is above $200K with couple of options, I saved +$50K.
Looking at Power/Torque curve compared to the GT3, the X51 is much better up to 6000RPM and holding very well up to 7600RPM. I also added the std 991s starting at 6500RPM. The X51 has also better low end torque up to 4000RPM and a smooth curve compare to the std 991s.
Where is the cut-off rpm rev limiter set on the X51 kit?
#98
Received 5,413 Likes
#99
#100
#101
For the 991S, why not just install the Fabspeed X-pipe race exhaust (25 HP gain) for $2k, $8k on a set of Penske or Moton shocks, and $4k on a set of R6's on lightweight OZ wheels? This 991S would beat both the X51 car and GT3... Just saying!
#102
Well, then you've spent $14k on parts not covered by warranty. And adding exhaust and light weight wheels wouldn't make the car faster than an X51 IMO. Aftermarket exhausts add HP (and I question the 25 in that case) but tend to kill low end torque, adding an exhaust isn't going to outperform better cylinder heads and intake.
#103
When comparing torque you've got to factor in the gearbox ratios and final drive ratio. The GT3 gearing is quite a bit different than the 991S and the Turbo cars.
Ryan
#104
I appreciate the graph, good information. I looked hard at an Aqua C4S with X51, but for me the GT3 won me over. For me it was just the right package.
Ryan
Ryan
#105
Yes and on the tracks that you shift into 7th at full throttle that will be really useful.....oh wait, yeah... Sorry.
