991 vs 991S with PSE
I thought all the PSE does is piping more sound into the cabin. Hence it sounds the same outside the car.
I do not have PSE in my C2S. What I noticed is that the exhaust sounds better if I turn the sport mode on.
My question to the guys with PSE: Does turning PSE on automatically turns on sport mode? Can you have PSE on and sport mode off? Does it sound different outside the car if you keep sport mode off?
Pse may be independently engaged and disengaged
Sport mode not required and PSE may be disengaged in Sport
Sounds the same outside of car with or without Sport mode? On a PDK equipped car, when the PSE is engaged downshifts are not as frequent and thus pops and extreme Pse bellowing are as frequent without Sport.
PSE consists of a different final muffler from the stock muffler with valves that open (i believe from the same vacuum line that operates the Sound Symposer valve) a more direct route for exhaust to escape. The "pops and burbles" are there in both the Carrera and Carrera S. The PSE allows them out with less baffling, so they are much more evident and louder.
