my 2012 991
Old May 23, 2013 | 10:16 PM
aljus's Avatar
aljus
Default my 2012 991
Hello Everyone,
Just purchased a 2012 991. Agate gray with Carrera s sports wheels. absolutely love the car. Drives and handles a lot better than my old 997. Just had a couple issues if you guys would be kind enough to respond.
1) the sunroof ( when its in open position) rattles when I go over a bump. Has anyone experienced that and what did you do about it?
2) when I come to a stop while the a/c is running I hear something in the engine compartment. It sounds like a clicking noise ( NOT the type of compressor clicking on/off) .
I appreciate any comments . thank you
Old May 24, 2013 | 01:06 AM
stevebmd's Avatar
stevebmd
My roof has rattled from day one. Supposedly there is a recall on it. There is an open campaign on it.
Old May 24, 2013 | 01:29 AM
duxsi's Avatar
duxsi
Sunroof clips need to be replaced. A very common issue. Dealer should know about this. Roof liner with be removed and the retaining clips replaced.
Regarding your engine clicking noise - Does it increase with RPM's or does it remain constant?
Does it make a difference if the AC is on or off?
And most importantly, it is intermittent?
Old May 24, 2013 | 05:32 PM
aljus's Avatar
aljus
thank you for your responses. clicking noise only clicks one time just when I stop. rpm has no effect on it. yes if the a/c is off it does not make that noise. No it is not intermittent.
I just have a feeling that it has to do something with the a/c running. Does anyone feel any difference when driving with the a/c on than off???
Old May 24, 2013 | 05:44 PM
neanicu's Avatar
neanicu
Do you have the Auto Stop/Start On? That's what you're probably hearing...the engine starting.
Old May 24, 2013 | 08:16 PM
holminator's Avatar
holminator
Ironically, my 05 997 had the same issue. They did fix it. Patience. Not that I used the roof all that much. My 991 is perfect on that score.
Old May 24, 2013 | 08:45 PM
chuckbdc's Avatar
chuckbdc
I have an early build 2012 that has had a couple of rattles tracked down and fixed. The sunroof has operated without any problems at all. No noises from the engine compartment except the sweetness.
