Using the same reasoning, why would you get PASM if you want a "purist" " feel?"
Totally different. PASM gets you 10mm lower, SPASM gets you 20mm lower, each with appropriately stiffer dampers. Car is VERY floaty on the base suspension, less so with PASM and MUCH less so on SPASM. SPASM does ride fairly stiffly, but I love it and after driving cars with PASM on the track, I would definitely order SPASM again.
After owning two base 991, I would go with the "S" option, it just "feels" better.
Oh and stay away from PSP.
From a power standpoint? Wouldn't the suspensions be identical if optioned the same way?
The base brakes are less powerful than the S's and the engine obviously lacks some grunt, but in my back to back test drives and especially when keeping the RPMs high, the base was very capable.
I did test a PDK, PDCC PASM C2S against a base Cab with passive suspension and 7 speed manual.
Meh. My base car is 7MT with 19's and no suspension options, and I think it's a near-perfect blend of ride/handling. Although I haven't tracked or auto-X'ed it yet, it has absorbed every road-going test I have thrown at it with aplomb.
Same here...no sunroof even. Frankly, I think the lower weight of the 19" rims + wheels also helps.
At some point, I may get some progressive lowering springs to reduce the wheel gap, and minimize any corner roll. I hear that those who lowered the car have even a bit tighter steering feel, as well.
+1
If he's looking for the most 'feel', I guess the question is does 'most road feel' mean firmest ride with no roll or most natural? SPASM sounds great in terms of choosing your ride stiffness, but 'natural' is more likely going to be the base suspension. PTV, PDCC, PDK, the Sport+ DEMs, etc. aren't going to get you more road feel. Less roll, more comfort, better track times, etc., sure, but it all depends on what you want from the ride.
I also love my base MT (also on 19's, no suspension options either), but test drive them and see what you like.
Right, and everyone's idea of feel is different. I would like the car to be planted on spirited drives and to provided quick throttle response and be 'immediate'. More sports car like as opposed to soft, lazy and floaty. If that makes sense.
I'm pretty sure all the configs are great actually.
Let me put it in another way. Does anyone really think that Porsche releases a "version" of their car/suspension that they consider unworthy? That would be a sure death in marketing. I believe PASM and SPASM first appeared when larger wheel/lower profile tire options first starting coming out. Those options would give back the ride quality of the cushier tires while getting some benefit from the larger combos. PTV and PDCC add other dynamics that are even more subtle.
It's only natural here that people will defend their choices, but might do things differently if they had it to do over again. I do not regret my low options car.
SPASM is option code 030. 030 used to mean ROW (rest of world). 030 used to be the lowest passive suspension available from the factory and was standard ROW.
US customers complained about stiffness and scraping the front and rear due to the lowered ride height. Thus 030 became an option in the US.
The base 911 suspension is called "US comfort".
The PASM suspension is the "active suspension" with two modes comfort and sport
I would not spec a 991 without SPASM. The other suspension options are trading comfort for performance. 030 means the way it's supposed to be.
You'll be fine with a bare bones Base, the sport car feel is all there. My Base w/o PASM rides perfectly planted, brakes are perfect and is plenty fast when you push it, but after living with a demo "S" for a week (not only short runs at the dealer), even though its not torque monster either, I was surprised that it felt much more powerful in the low to mid rev range, thus made my experience more enjoyable. It just feeled sportier when driving it in a more relaxed manner.
My point is that if you want to load a Base with the options you are considering, you better stretch a bit and get the "S", the Base car is very capable as is.
What would you select on the option list if you were getting a 991 but were interested in the most road 'feel'?
Coming from a spyder and getting into a Carrera, I'd like to retain as much of the involvement as possible. 'Driver's' car.
I know it will have to be 7sp manual and I'll check the sports chrono box. SPASM worth it on a base, considering the requirement to also pay for PTV and 20" wheels (bringing the price very close to 991S)? 20" wheels providing more feel than 19s?
Appreciate the input.
Agree with most of the posts. For feel:
- Definitely SPASM (lower cg, crisper turn in and exits with minimal body roll) w/o PDCC (heavy and no cornering weight transition feel).
- MT
- Low weight: Sport Seats Plus w/o cooling, no sunroof, base stereo
- Technically the PCCB should be good for lower unsprung weight, but I have no personal experience with it. Price is a bit on the high side....
- Sport Chrono
an S with X51 is worth it IMO, but quite expensive.
Sport PASM in addition to lowering the car 10 mm more than PASM and 20 mm lower than standard, has stiffer springs and sway bars. Taken together all that changes many variables: the center of gravity is lower, the handling is "tighter" (but not relatively "harsh" as had been the case in pre 991 models). The steering feel is a bit more to my liking in terms of precision and road feel, compared to 991s without it, but without the "noise" of the traditional 911. I used think that was involving- in my 74 911 S and 78 SC and 08 Boxter S. But to tell the truth I am more involved placing the car and slowing down at the higher speeds and cornering forces of the 991.
I can believe that for the track; it's nowhere near any limits on the stock base on any roads around here (be it smaller back roads, out by Shenandoah, etc.) at least not without looking at a reckless citation if a cop notices you. Having a bit of roll and some bumps passed along lets the car feel like it's at least thinking about the road in normal street driving, at least for me.
Most 'feel' and 'involvement' a la Spyder would be a car without PASM or SPASM. With 'active' dampers there is a layer of computer intervention between your butt and the road - and therefore less of the analog 'feel' that the Spyder is all about.
Your butt will feel less forward thrust in a base 991 compared to the Spyder as well...
