X51
A little more info on the engineering behind the Powerkit for the 991:
http://www.porscheengineering.com/po.../index.html#28
You'll need to buy less parts because of the options you already have on the car. Dealer can quote the parts you will need and labor, which will run about $20k installed I believe. Warranty is retained. Factory option if the box was ticked ran a little over $10k if I recall.
I think so too, unless u need the top revv range a lot like for tracking or autobahn otherwise wont be too valuable. Though I would love to have the center radiator instead of a plastic hole.
I'm expecting that Porsche, in their typical fashion, has understated the gains an X51 upgrade will bring. If Porsche says 0.1 second improvement to 0-60 I'll bet its at least 0.2 which I believe was supported by a french rag.
Really hoping to see some dyno comparisons soon.
