PDK Doughnut Mode Carrera vs GT3?
![Thumbs down](https://rennlist.com/forums/images/icons/icon13.gif)
So, much has been made about the GT3's pull both paddles for neutral for spin outs, standing water, hooliganism around curves, etc. But is the GT3's both paddle pull any different than the Carrera's neutral by paddle pull?
But in the 991S PDK, pull bothaddles and you have Nuetral. Then pull either Right or Left and it selects the appropriate gear.
Yes that is my question. At GT3 launch Preuninger made a big deal about being able to pull both paddles. My reaction was, ok, that is not new. So I was curious if there is a substantive difference between the two neutrals. (I do understand that the PDK is 'tuned' differently for the GT3.)
Maybe you jump back to the previous gear that was engaged when you release the paddles vs staying in neutral and having to then manually shift??? Not sure what I am saying makes any sense. Donuts in a 991 C2S PDK isn't a problem though
O.K., I'm not not near my car right now or I would try it. How long does it remain in neutral after pulling both paddles?
It remains in neutral until you pull a paddle again.
I must say though, it will take some learning if one needed it in a hurry and for it to be a reflex. Not that paddles aren't quick or effective, but I am pretty sure my left foot will nail the phantom clutch pedal into the floor first, lol.
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Paddles not required for simple donuts. Not an expert, but turn off all thenannies, just get the car to oversteer a bit and then floor it to make the rear break loose while making a very sharp turn. After that just follow your instinct to modulate the throttle and steering wheel angle. When you stop drifting and want to stop the car, you may want to go to neutral to avoid the risk to go backwards with a forward gear engaged.
Here are a few donuts I did with my first 991S last year just before I had to replace the tires. Did not try since then, I know it works and it really does not serve any purpose![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
One more tip - if you are at a red light and pull both paddles, the PDK car will go into neutral. However, you have to step on the brake before it will shift into gear when it's time to go! Looks sort of silly to be sitting there revving the engine while sitting still!
In a Carrera, pulling both peddle is like shifting the car into neutral.
In the GT3, pulling both peddle is like stepping on the clutch while the car is still in gear, you can rev the engine up and drop the clutch like a normal manual car. (for whatever reason)
Pardon my density, but what's the difference in a millisecond shift world, of remaining in gear with auto clutch pulled vs clutch pulled in neutral? I suppose a few milliseconds to re-engage gear?
I haven't actually tried this from standstill in the C2S -- anyone?
This being from the the Road & Track GT3 First Drive article:
"The GT3 also reacts more quickly to shift requests than does the regular 911, and Preuninger even installed a clutch-dump function—pull both paddles in any gear, and the engine will freewheel. Release them, and drive will gently reengage. If you're in Sport Plus mode, the gearbox will unceremoniously dump the clutch.
"I wanted to make sure I could still do a burnout when I pull up next to a Prius at a red light," Preuninger says."
In the GT3 you can "drop the clutch" by pulling the paddles in while the car is motion in any gear (as it's been described). You cannot do this in a C2.
This is not correct. You can pull both paddles at any time in any gear and get neutral in a C2 (S at least, don't think the C2 differs?). Another paddle (or shifter) pull gets you back in gear.
