Looking for slotted rotors for 991 CS.
I need rotors and pads on my 991 Carrera S and since the car sees quite a bit of track time, I'd like to go slotted vs. drilled. I'm having a tough time finding any options. Any recommendations?
Unfortunately, I have not seen any aftermarket rotors or pads yet for the 991. Pagid is coming out with a track based pad in May according to the Suncoast folks. I think you may need to do one more round on stock rotors and pads until the after market catches up.
S brakes are 340 and 330
Carrera's are 330 and 330
Rotor thickness is the challenge (in order to use the factory calipers.)
I see some upgrades available (larger diameter 350mm front and rear.)
You could contact Brembo, Stoptech, Porformance Friction or Movit.
I think Alex @ Sharkwerks has done some slotted rotor upgrades for the 991. You should check with him to see what's real and what's imagined.
http://sharkwerks.com/products.php?m...31&type=Brakes
I think I'll do something when PFC offers a rotor/pad for the 991S using the factory caliper.
