Easy to dent!!
Old Mar 27, 2013 | 08:41 PM
carrerapete's Avatar
carrerapete
On page 216 of the owners' manual they clearly specify that the use of a ball peen hammer for bird-dropping removal will void the warranty.
Old Apr 22, 2013 | 04:07 PM
Venturi's Avatar
Venturi
On Denting:
I live in fear of denting the front hood when closing it. I saw two 911 at dealership with slight body deflection around front emblem. I've been trying to use both palms and flat and push lightly, but seems an inordinate amount of pressure to close it. Am I being to delicate?
Old Apr 22, 2013 | 04:57 PM
LonnieR's Avatar
LonnieR
Originally Posted by Venturi
On Denting:
Always found that palm down on the emblem with quick pressure does the trick. Any aluminum surface has to be carefully considered.it dents easily and can be a bitch to fix ( if it goes beyond your usual dent dr amount).
My son has a Panemara GTS and he put two small dents in the rear passenger door. They had to replace the door because they did not not think they could get the contours right . Cost him (insurance) almost $11K!.
Old Apr 22, 2013 | 11:01 PM
meine911's Avatar
meine911
Always found that palm down on the emblem with quick pressure does the trick. [/QUOTE]
To be extra safe, I prefer to press down close to the edge. I've been told that too much pressure around the emblem could cause a dent.
Old Apr 23, 2013 | 02:45 AM
ww007's Avatar
ww007
To be extra safe, I prefer to press down close to the edge. I've been told that too much pressure around the emblem could cause a dent.[/QUOTE]
Yeah my dealer told me to never push down on the emblem itself when closing the hood as it's very delicate around there and may dent. He said it's better to push on the area in front of it.
