Hi, before you jump on me I have read the manual. Starting today when I hit the lock button on the key the lights flash twice but the acoustic signal is gone upon locking the car. It had been working fine with the 2 short beeps originally. I have checked settings but cannot figure it out. How can I reset the remote key locking to give me the audible 2 short tweets when locking. I do have keyless go as an option on this new 991. Thanks.
You may have turned down the volume for your alerts? dont know if thats connected to door lock chirp, but try iy.
or-
Put the key in the house.
Get the other key and go for a ride. Return, park, lock.
Just tried the panic button for the heck of it & the lights flash but no sound. What could have shut the audio off?. I checked settings and all looks ok.
Bizarre. Sounds like a software issue. I think the tone of the panic button and the confirmation chirp from the alarm come from different devices. The alarm horn is purposefully hidden to make it difficult to disable or muffle. It used to be easy to spray expansion foam and muffle the honker.
Thanks, the horn works. I checked the manual but could not find a fuse associated to the acoustic signal. I saw one for the led locking flash but that works too.
