A/C Odor
Does anyone here experience an unpleasant odor from the A/C once it's first turned on? The dealer blames it on Houston's humid weather, so I am more inclined to hear from other Houstonian owners or those from towns with similar climate. We have brought it back to spray some sort of chemical in the vents, which only remedied the problem for a very short period of time. They also tell us that there's nothing else they can do. We also only noticed this after the A/C recall was done on our car...could be a coincident, but I wonder if it was related. So, are others here experiencing the same thing?
Cheers,
Kevin
Cheers,
Kevin
I've always heard to shut you A/C off right before reaching your detestation but leaving the fan on to dry out your A/C lines. I've always done this on all my cars and haven't had an issue as of yet but have smelled it in other peoples vehicles, maybe someone else has a better solution but that has always worked for me.
Sounds like the drain line might be plugged. This allows mold/mildew-like organisms to grow in the evaporator housing. The dealer techs may have kinked or otherwise blocked the drain line while performing the recall work, so that would be the first thing to check.
If the service techs sprayed stuff into your vents and didn't bother to check the drain line first, that is a sign you don't want them within 100 yards of your car. It'd be appropriate to find another dealer or indy shop.
Cheers,
Kevin
Cheers,
Kevin
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Cheers,
Kevin
Cheers,
Kevin
Had no idea even though for Miami, very humid in summer. Note the Coconut Grove pic. Hope it's nothing. I never had that problem.
I tell yah. I get no respect. For my brother Rodney. I miss you hommie.
Alright, I will order the filter and change it out. Hopefully, I will report back with good news, but I highly doubt it will solve the issue though.
1) Remove the cabin filter. Inspect it. If you find black or green mold, that's a source of the smell. Order a new filter and replace it.
2) While you have the filter out, grab an inspection mirror, flex light
or borrow an inexpensive fiberscope if need be (I forget how far away the evap coil is from the filter). Inspect the evaporator coil for the same contaminants (black or green mold). There are products available,Air Conditioner Deodorizers, at the local brick and motar auto parts store to spray on the evap coil to kill the mold and reduce odors
Here is a more intuitive suggestion.
or borrow an inexpensive fiberscope if need be (I forget how far away the evap coil is from the filter). Inspect the evaporator coil for the same contaminants (black or green mold). There are products available,Air Conditioner Deodorizers, at the local brick and motar auto parts store to spray on the evap coil to kill the mold and reduce odors[/QUOTE]. By the way, keeping the 'mold' off the evaporator coil will extend its life (contaminants hold moisture for long periods of time, leading to ->corrosion->leaking coil; especially on thinner plate and fin designs as found post 993, i.e. 996, Boxster, etc.
or borrow an inexpensive fiberscope if need be (I forget how far away the evap coil is from the filter). Inspect the evaporator coil for the same contaminants (black or green mold). There are products available,Air Conditioner Deodorizers, at the local brick and motar auto parts store to spray on the evap coil to kill the mold and reduce odors. By the way, keeping the 'mold' off the evaporator coil will extend its life (contaminants hold moisture for long periods of time, leading to ->corrosion->leaking coil; especially on thinner plate and fin designs as found post 993, i.e. 996, Boxster, etc.
