AC question....need to know if normal
Old Feb 27, 2013 | 04:22 AM
Faiz Merchant's Avatar
Faiz Merchant
8th Gear
Default AC question....need to know if normal
Every time I start my car the AC comes on. Even after I turn off the AC and then turn off the car, the next time I start it the AC is on at the previous setting. Dealership says that's normal and I'm not convinced. Please chime in
Old Feb 27, 2013 | 06:58 AM
draxa's Avatar
draxa
It's normal; irritatingly so, but seems to be the default (un-alterable) setting.
Old Feb 27, 2013 | 09:18 AM
WCE's Avatar
WCE
User
Mine stays off (or on) ... are you in "auto" mode perhaps?
Old Feb 27, 2013 | 10:48 AM
docmalone's Avatar
docmalone
Mine also stays off if I left it off. I have not done any personalization of the AC system in the PCM menu but there may an option in there.
Old Feb 27, 2013 | 12:26 PM
GSIRM3's Avatar
GSIRM3
Is it possible that it is a key memory setting you have set?
Old Feb 27, 2013 | 12:37 PM
TSpyder's Avatar
TSpyder
Perhaps the OP is not located in NA. Note that post #2 is from someone in the UK.
Old Feb 27, 2013 | 11:02 PM
Faiz Merchant
8th Gear
I'm in Texas. I have a 2013 S cab. It's an annoying issue because I usually drive it with the top down then notice the AC is on. I can't find any setting to stop this
Old Feb 28, 2013 | 04:00 AM
TSpyder's Avatar
TSpyder
Ok, so much for the "only outside NA" idea
Anyway, mine remains in the prior position when the car is restarted.
Old Mar 2, 2013 | 01:22 AM
holminator's Avatar
holminator
I had the same reaction when they told me the engine was in the rear of the car. I still don't believe it.
Old Mar 2, 2013 | 01:34 AM
SSST's Avatar
SSST
Being in Texas you won't think it's annoying starting in about late May. Top will stay up and AC on from June to mid October.
You can stretch it a little if you have the top down and cold air blowing into the footwell, but once temps get into the 90s don't make yourself miserable.
Old Mar 2, 2013 | 01:52 AM
pfan's Avatar
pfan
If you have the 14 or 18 way electric seats with memory you should be able to store your a/c settings.
http://www.porscheownersmanuals.com/.../6/31/Settings
Old Mar 2, 2013 | 01:49 PM
ohniner's Avatar
ohniner
Just about everything else is remembered by key memory settings but whenever the car is started it defaults to "mono" at lowest fan position. 2013 Carrera cab, dealer said it's normal.
Old Mar 3, 2013 | 05:50 AM
SiNi's Avatar
SiNi
My AC settings are remembered so when the car is unlocked everything is set to how I want it. The only thing that isn't remembered is the TFT dash screen which always defaults to the radio display. Odd?
