991 manual transmission question
#61
#62
I assume you are meaning to skip gears (i.e. downshift from 6th to 3rd)? Anyways, the computer always knows what gear you are selecting and knows how fast the car is traveling, so it's an easy computation to know what revs are appropriate (just as any decent driver would know).
Granted- it may dumb down some drivers.
But I would be happy to take your $$ and turn it off for you.
#63
I am REALLY liking this feature of the new M/T. Since I have always driven manual trannys and have not warmed up to the PDK, I am now leaning toward the M/T. That said, this does NOT circumvent the possibility of the "MONEY SHIFT" (i.e. overrev downshift leading to blown engine). Is that correct ?
#64
#65
Gary
#66
Granted that almost anything is possible, but it would be challenging to write code that would anticipate a dangerous shift. You could prevent downshifting more than one gear at a time, but I don't think most drivers would want that.
#67
What? That's a 4th grade math problem. The code is already written anyways - that's how the system knows how to rev-match the downshifts. It calculates the revs required based on vehicle speed and gear selection. If the revs required are higher than the redline, then lockout is activate. Pretty simple. This is how a dangerous shift is avoided with PDK too.
#68
The corvette manual has forced a 3rd to 6th (I believe) upshift for years when driving gently for better fuel economy. This same gear lockout solenoid concept could keep one from engaging to low a gear - seems like a great idea to me.
Surprised no one has done this yet and even more surprised it's not an advertised feature of the new 2014 corvette's trick 7-speed manual!
#69
If the programming is just a 4th grade math problem to you, I'd suggest that you contact Porsche. I'm certain that they would pay you a premium for the program since it would be a no brainer to add it to all of their manual transmissions.
#70
I should have bolded the word anticipate. Mechanical downshifts present an entitrely new set of challenges than do automatted PDK shifts. The rev match calculation is made when the gear is selected, and not before.
#73
Probably the easiest way to do this would be to place a removable obstacle in the shift gate for each gear. At rest all of the gates would be open. At speeds beyond which redline occurs in 1st gear, 1st gear's solenoid-controlled obstacle would be in place, etc. That way there would never be a gear available that would over-rev the motor. Very simple and no anticipation required - just 4th grade math to know which gears should be available for the given road speed of the car.[/QUOTE]
#75
How about we don't give them any more bright ideas? Manual transmissions should be manual, with less stuff to break. PDK transmissions should be the option for those who want the best available technology.
