Oil Change - No Readout
Old Jan 2, 2013 | 11:50 AM
pfijcali's Avatar
pfijcali
Default Oil Change - No Readout
I changed the oil/filter on my 2012 991S at 2000 miles (I know - I didn't have to change the oil now, but it gave me something to do over the holidays), and now the oil level readout in the cabin does not return a reading. I filled with 7.5 quarts of Mobil 1 0-40W and changed the filter with an original Mahle. I compared the filter number on the original filter with the replacement filter, and the numbers match.
Does anybody have any idea why I can't get an oil level readout anymore? Any ideas are welcome.
Old Jan 2, 2013 | 11:53 AM
KINGSRULE's Avatar
KINGSRULE
You need to add more oil.....
Like 2 quarts
Old Jan 2, 2013 | 12:16 PM
pfijcali's Avatar
pfijcali
Thanks for the suggestion. I'll try adding a little more oil. But I surmise the readout would give me a low level warning if I hadn't added enough oil.
Old Jan 2, 2013 | 01:25 PM
shizzle's Avatar
shizzle
When I first changed the oil in my 991, it took a while to get a new oil level reading. Basically had to drive the car around and get it to temperature, and only then did it give a readout.
Old Jan 2, 2013 | 02:10 PM
MJBird993's Avatar
MJBird993
You need to drive 9 miles before the car will give you get a readout.
Do not overfill!!! Don't put in two quarts. Put in one quart. Drive for 9 miles, get reading, add more as needed.
Old Jan 2, 2013 | 02:36 PM
jmct's Avatar
jmct
I thought there was an old-fashioned dipstick as well to check the oil level? I would think that is preferable to guessing how much more oil to put in the car to drive around with while the system recalibrates/comes on.
Old Jan 3, 2013 | 12:07 AM
gota911's Avatar
gota911
Newbies Hospitality Director
Porsche did away with the dip stick in the 911 beginning in 2005 with the launch of the 997.1.
Old Jan 3, 2013 | 12:46 AM
neanicu's Avatar
neanicu
I think earlier than that. My '02 996 TT doesn't have one either...
Old Jan 3, 2013 | 12:51 AM
jmct's Avatar
jmct
I could have swore I checked the oil on my 997 using a dipstick once, and just went to go and take a photo and prove you all wrong. It ended badly.
Old Jan 3, 2013 | 09:25 AM
chuckbdc's Avatar
chuckbdc
ROFL
Old Jan 3, 2013 | 11:40 AM
KINGSRULE's Avatar
KINGSRULE
The oil change w/filter capacity is 9 + quarts.....
Old Jan 3, 2013 | 12:54 PM
holminator's Avatar
holminator
Honest men are hard to come by these days. Hand salute!
