want to shave some pounds?
Wish the retailer had some hard numbers of things like shorter braking distances, better acceleration, etc. Otherwise I would not have any idea if it is truly worth the money. I could be wrong but Porsche also never published data on how much improvement in things like braking distance, etc. that PCCBs have over conventional Porsche brakes. Dumb question probably since I'm not an engineer, but what happens to a carbon fiber rim if I hit a really nasty pothole. Does it shatter or maintain its integrity like an aluminum rim?
Reducing the overall weight of the car will improve its ability to accelerate and slow down. So, if each carbon wheel (with tire) weighs 40 pounds less than the stock wheel (a very dubious proposition) , the effect will be about like not having a 160 lb passenger along for the ride. You can extrapolate to get the advantage of hiring a jockey (or a typical F1 driver) compared to whatever you weigh. In a 400 hp car, you would need a stopwatch to measure the advantage in any case.
Reducing the weight of each wheel (with tire) on the other hand, will allow the springs and shocks to better keep the wheel against the ground. Even a much smaller weight reduction per wheel (~5-10 lbs) would have a substantial effect. How much would depend on your spring rates and rebound mappings- but it would not take much for your car to behave better - whenever the wheels move up and down, they will do it faster.
Gary
Gary, Porsche says the obverse on braking distances: "PCCB enables shorter braking distances in even the toughest road and race conditions," and I believe it.
http://www.porsche.com/usa/models/91...detail/safety/
I would like Porsche to tell me by how much someday. Ten thousand bucks is a lot to ask for an undefined capability improvement.
The sales literature states clearly: "The key advantage of PCCB is the extremely low weight of the ceramic brake discs, which are approximately 50% lighter than standard discs of similar design and size. As well as enhancing performance and fuel economy, this represents a major reduction in unsprung and rotating masses. The consequence of this is better road holding and increased comfort, particularly on uneven roads, as well as greater agility and improved handling."
Of all of the effects, the one that you would feel - in comparison to a car with stock steel brake disks, would be the improvement in suspension response. Even a few pounds per wheel is noticeable. The one thing of which I am certain is that improvements to the technology that affects performance has a constant effect: your bank balance gets lighter and you go faster.
They don't tell you because the stopping distance advantage (due to lower vehicle weight) is unimpressively small. They dissipate heat faster and should prevent fade and hold up better- but you would have to be going fast in race conditions to get that advantage over the enormously good standard brakes (especially with the S calipers).
Well done ...
Carbon Revolution claims to have the world's first one-piece carbon-fiber wheels, and they're already available in very limited numbers for the Porsche 911.
The 19x8.5 and 19x12 wheels mount directly on any of the water-cooled models, accept the original factory center caps, and are compatible with the OEM tire-pressure monitoring system. And on a 911, Carbon Revolution cites a weight savings of more than ten pounds for each wheel (a total of 41.2 pounds, or 18.7 kg).
Now for the sticker shock: At a cost about $15,000 a set, they'll significantly lighten your wallet, too. But the company does point out that this is the equivalent of adding horsepower, bolstering the brakes, improving grip, upgrading the suspension, and/or adding more sound insulation.
Read more: http://www.foxnews.com/leisure/2012/...#ixzz2GaepCv7q
Special pads and rotors retain their ability at high temps to grip the disk and modulate the drag in a linear way around the levels that produce tire lock-up. Linear modulation is essential for a highly skilled driver, but also for a top ABS system like ours. The PCCB system presumably -- though I haven't tested them on on a road car -- will operate at those higher temperatures. The iron disks and street pads will not. Fluid boils for example, so it is necessary to add cooling capacity if you push iron disks to that extreme. If the PCCB has those mods as well, then the answer is yes. If it does not, then it will just glow more prettily while it boils the fluid.
Now. Does that shorten stopping distances? Well, certainly if you compare the PCCB's with supplemental cooling to an iron disk system that has been driven to temps so high the fluid boils. In other situations... well, it could retain more controllable linearity to that higher temp. If the system is more linear, then ABS or the highly skilled driver will be able to stop sooner by keeping the tires right on their peak braking level of slip.
We're talking about pretty marginal increases in that last case. Ditto the handling improvement of lower unsprung weight. A related small improvement in braking comes from the more consistent clamping force when the tire is held more adroitly against the pavement by that better suspension. We're talking really fine-grained changes now. But of course efficiency is made up of a great many very small increments of improvement. Whether this particular small increment is worth your money is a very personal decision.
But in general, you cannot push modern Porsche brakes to their extreme with sane driving on public roads. And absent those extreme heating conditions, the car is limited in braking distance by the tires you have mounted.
Gary
