Wondering if the PDK will let me....?
I will soon take delivery of a 2013 991 with PDK and PSE that has been on order for several weeks. With the selector in the manual mode, and in first gear, will I be a able to rev the engine a little when the vehicle is stopped, or slowing down while coming to a stop [for example, while sittng at a stop light, or coasting into a parking space] as one can do with a MT?
Rumor floating around suggests that pulling on both paddles (aka Ferrari) will put PDK in neutral. Always meant to try it at the dealer, but never remembered. Then you should be able to rev a bit and then pull the up paddle to place in gear again. Anyone try this?,....does it work with wheel buttons also?
Yes this works, then again the same thing could be achievable by simply reving in neutral and dropping it into gear - just like we used to do to our parents automatics when learning to drive! Anyone with a leased 991 they're not attached to want to try a high rpm clutch drop and report back if it works like launch control?
Personally, I skipped sport chrono just to avoid the temptation of launch control (and I have no need for off-track redline shifts). I had an Audi TTS with launch control and pretty much buggered up the first gear clutch from the abuse. The PDK in this car is so smooth and I'd like it to stay that way. By the way, these cars definitely improve with mileage and use. My Carrera finally feels like it has 350HP and I'm definitely looking forward to a track event next month!
Interesting, must be a new PDK feature on the 991. The version in my '09 C2S won't do that.
I think thats a mistake - regardless of LC. I have probably used LC 5 times in 18000 miles but use SC to adjust settings every time i drive it. If you get PDK you must get SC. Normal mode is very "boring". BTW, you can retrofit without the dash "wart". Although I like the wart.
This is correct. Pull both paddles for neutral. You can only reengage first gear by placing foot on brake and pulling paddle again. If you want some revs you'll need temprarily to use that left foot for the brake
When you pull both paddles at the same time, you are simultaneously signalling for an upshift and a downshift. When you pull both buttons each button is signalling for a downshift since they are redundant. You may be right, it might work, but they would have had to design PDK to respond to different commands with the buttons than with the paddles. Or maybe push on one button and pull on the other....but which one to push and which one to pull?
You can slip in and out of neutral any time, rolling or at a complete stop. It's a great feature.
