Changing brake pads on a 991S
Old 05-22-2013, 10:08 PM
  #31
shizzle
shizzle's Avatar
Originally Posted by Carrera GT
SRF is a waste of money and may not even be suited to the seals in the 991. You might get a Porsche dealer to confirm it's acceptable, but it's still a total waste of money. Ate or Motul are above the limits of the rest of the system. I run boring, old Ate in an RS 3.8 running Hoosiers at decent pace with zero problems.
I'm curious about the Brembo rotors. Last I checked, no OEM/aftermarket rotors were the correct thickness for the 991 calipers. I'm keen to upgrade to slotted rotors from PFC, Brembo, Stoptech or equivalent. The factory pads are the first weak link. Plus braided flex lines. A little oversized with spacers for the calipers would be fine, but right now, I don't think the brakes need anything except light, durable rotors. The factory rotors are giants, which I think is mostly related to the rears being over-engineered for PSM and PTV.
I'll have to respectfully disagree with you on SRF. It is fully compatible with the Porsche brake seals (confirmed by a Porsche mechanic), it is a DOT4 product and used extensively in motorsports. I know several GT3RS owners up here in Canada that swear by the stuff . I think Motul 600 and 660 is great stuff, but I find SRF doesn't need to be bled anywhere near as often.
I agree with you on the pads. I wore out 2 sets of OEM pads last season and i've switched to Pagid RS29 now that they're out.
Originally Posted by Cogito_Ergo_Zoom
Hi, can you share the details on the discs..from Suncoast?
The brembo rotor kit I am referring to fits the stock calipers. They are stock width, but are 10mm larger in diameter in the front and 20mm larger in the rear. The part numbers are 102.8010A and 202.8009A if you're interested. I got a pretty good deal through Gruppe Werks (www.gruppewerks.com) on the kit.
Old 05-22-2013, 10:25 PM
  #32
Cogito_Ergo_Zoom
Cogito_Ergo_Zoom's Avatar
Found em here, thanks: http://www.gruppewerks.com/collectio...e-front-rotors
Very lustworthy.
Old 05-22-2013, 10:27 PM
  #33
shizzle
shizzle's Avatar
Very lustworthy.
I know! I can't wait for their arrival. If you email them, they'll give you a better price that what's listed.
Old 05-22-2013, 10:29 PM
  #34
Cogito_Ergo_Zoom
Thanks for the tip. These will most definitely go on when the OEM rotors are done, which won't be too long.
Old 05-23-2013, 12:10 AM
  #35
STALKER99
STALKER99's Avatar
I got my RS-29s from Gruppe Werks, good price and good service. Quick turn around.
I also purchased my SRF from them. I love the stuff. I only bleed my system once a year with SRF and it has never failed me.
Old 05-23-2013, 12:32 AM
  #36
TRAKCAR
TRAKCAR's Avatar
Received 1,639 Likes on 761 Posts
I love SRF..
Old 05-23-2013, 01:00 AM
  #37
MayorAdamWest
MayorAdamWest's Avatar
Girodisc is available as slotted in 991 sizes. I was quoted around 2400 for the set, front and back.
Old 05-23-2013, 01:05 AM
  #38
John's 991
John's 991's Avatar
Wow, those look like nice rotors. But $2,500 for the fronts compared to $400 for stock. They better be pretty darn good!
Old 05-23-2013, 03:23 PM
  #39
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Pads arriving for the 991 - finally!
Old 05-24-2013, 10:41 AM
  #40
SB
SB's Avatar
Default Does anyone know caliper bolt tightening torque specs?
Old 05-24-2013, 08:22 PM
  #41
shizzle
shizzle's Avatar
I was told by the dealership 63ft-lbs.
Old 05-24-2013, 10:08 PM
  #42
SB
SB's Avatar
Same as 997. thanks for the info
Old 07-29-2014, 03:08 PM
  #43
TrackDays247.com
Former Vendor
Pad / caliper spreader for 4/6 piston Porsche brake setups AND 991/991S pads IN STOCK
Old 07-30-2014, 11:54 AM
  #44
4forme
4forme's Avatar
Girodisc 350mm front setups for the 991 are $1,200. The $,2400 quoted above is for front AND rear.
Old 07-30-2014, 01:39 PM
  #45
TrackDays247.com
Former Vendor
Yes, and through Rennstore it is LESS than that with a bonus.
Quick Reply: Changing brake pads on a 991S
