Lindsay Lohan crash tests 991
#47
I think it could be a track car build.
Hopefully the steering is cactus -- I'd try to put a 997 rack in there with an electric-hydraulic pump out of a Cup, pull off the other front fender and put on 997 RSR front panels, hang a wing on the back, disable all the electronic systems, spherical joint suspension rebuild, lsd, strip the cabin, cut out the sunroof, weld in a cage ... tweak the engine for 450hp ... bingo -- 2800lb "drive to the track" car.
#48
20 k are you kidding me. Airbags alone will cost 5 k to replace. I was stuck in a hailstorm and had 17 k damage. Here you have bumper, front qtr panel, front radiators, right front suspension elements, hood , both light assemblies, foglights, front valence, frunk assembly, sensors as well as repair right door, right rear quarter repair,etc etc etc, even if the frame is straight your way above that number
