Park Assist Control Module
Parking brake control module is on the Left side behind rear seats and carpet. Pictures and videos below.
Park brake control module
911BOSS (09-04-2024)
hello,
the latter is located under the driver's seat, if you are talking about the reversing camera and radar manager.
I will try to replace, normally this weekend, my calculator initially present on my 991.1 gts. I installed the pcm 4 at the beginning of the year on it, everything works except the camera and the display of the reversing radars, even if the latter beep.
So I hope to rectify the situation by installing the calculator 95B.919.475 in version L.
Best regards.
Best regards.
Good morning,
the latter is located under the driver's seat, if you are talking about the reversing camera manager and the radars.
I will try to replace, normally this weekend, my computer initially present on my 991.1 gts. I installed the pcm 4 at the beginning of the year on it, everything works except the camera and the reversing radar display, even if the latter sound.
I therefore hope to rectify the situation by installing the 95B.919.475 calculator in the L version.
Kind regards.
Kind regards.
I failed to mention mine is a cabriolet. Under the driver's seat is the body control module in my car. I checked the part number and believe the PA control module to be a different and separate controller. I don't know if the PA Control module is under the dash or where.
If I'm not mistaken, most things are located in the same places in both cabs and coupes of the same gen. The difference is how you get to them. Things that are accessible behind the back seats and cover panels in the coupe are accessible in the cab by putting the top in the halfway position, and removing the small covers over the pop-up roll bars.
Thanks Foosh. I have looked in the package tray area and even found another module under the rear left seat, all to no avail. I have ordered a headlight wrench in preparation for my search on the front of the car. I will also be looking in the frunk more closely, and behind the radio.
Well, I stand corrected! It was underneath the driver's seat, below the reinforcement plate and near the body control module. I have ordered another one because there is significant corrosion on the board. I will keep you updated when the new one comes in.
Yeah I dont think that compartment is fully sealed so I'm not surprised there was corrosion, pics would be interesting though.
Mine went out immediately after driving through water that was up to the floorboard but not over the doorsills, the amplifier is under the passenger seat in the similar location.
Kinda sucks that the BCM, park assist and amp are all at the lowest point of the car.
