Air bag warning after seat removal
I pulled the passenger seat from my 991.2. Now the airbag warning light stays on. Is there a way to reset this, either with an ODB, or via the dealer, or do I need to short two wires in the plug, or do I put black electrical tape on the dashboard?
The following 3 users liked this post by ShootingSight:
If the seat is completely removed, I believe you would need to follow the process detailed in this thread, though I presume only the settings pertaining to the passenger seat would need to be changed: https://www.planet-9.com/posts/2196907/
If you do not have access to a PIWIS, I have found these settings are available using a ThinkDiag OBD tool as well, though I have not tested it yet myself (will be giving it a try in a couple weeks when I have all the parts to swap seats on my Cayman). So attempt at your own risk.
ShootingSight (06-05-2024)
You need a few things and it won’t cost a ton. I would source a passenger side wiring harness from a 911 or panamera. You would need a few things to make this work.
1.) seat position sensor - easily removed from your seat
2.) occupancy bladder from eBay
3.) occupancy compute from your existing seat
4.) resistor for the passenger side airbag
5.) a seatbelt receptacle from your old seat or one from eBay from a Panamera or 911 or cayman or similar era.
6.) wiring harness from a 911 or Panama or cayman to plug all the above in OR take the one off your existing seat.
without all the above items plugged in the computer will always throw an airbag light.
good luck
good luck
Not an ideal solution though because with the light disabled, it won't come on if one of the other airbags has an issue.
If I can't find a way to make it work with ThinkDiag, will probably ultimately either buy/borrow a PIWIS or try improvising all the necessary connections to the wiring harness as the other poster suggested.
Called my dealer, they said Porsche does not give them the ability to get into the config side of software - all those options are greyed out.
Called Porsche NA, they had never been asked this question before, had no idea how to address it, had no idea where to direct me to ask further.
Might try calling Porsche Germany.
Actually, I have found that the light is pretty easy to ignore. I'd still like that it worked, so if I had a fault with any of the other airbags, I'd know. But failing that I can live with it.
Pulled out the rear seat and fabricated a shelf that just about comes even with the top of the transmission tunnel, giving me max flat space in the back, so now set up as a 1 person + 2 dog daily driver. I just have to drive easy when they are with me.
good luck
good luck
i actually just did this using an eBay occupancy sensor.
ShootingSight (06-09-2024)
