New 991.2 Owner - A Few Questions
I've owned my 991.2 C2S for about a month now and so far I'm loving it. Having just come from a 997.1 C2S, the performance and refinement of the 991.2 has been a welcome upgrade. I've spent a lot of time researching here on Rennlist and elsewhere, but was still hoping for a little clarity on the following:
- Climate Control always comes on
I think I already know the answer to this, but figured I would double check with the braintrust. Is there a way to program the climate control to remain off when you get in a start your car? I was able to program it so that the AC doesn't come on and the temp setting remains the same, but I rarely use the climate control in my 911 and on the rare occasion I do, I'll just turn it on myself. From the threads I've read here and from talking to my sales rep at Porsche Palm Springs, it sounds like the climate control will always come on regardless of programming the key and the individual settings. Does anyone here know of a way to program your settings so it remains off?
- Rear Axle Steer Alignment
So far I'm really digging RAS. It makes the car feel as small as my old 997 in tight corners, but also makes it feel more stable at speeds without if feeling like it is intrusive or even there. My question is how much does a dealer or an Indy typically charge for a 4-wheel alignment on a car with RAS? Also, has anyone here had any issues with RAS? Alignment issues, components failing, etc.? It seems like a fairly straight forward and robust system, I'm just curious if there is any longer term cost of ownership issues with RAS equipped cars that I should be aware of. Also, is it worth rotating the tires side-to-side every 5k miles or is that even worth the hassle considering the 15k-20k mile lifespan of summer performance tires?
- Brake Dust
A common mod/upgrade on the 997's is to upgrade the brake pads to Hawk Performance Ceramic pads. I did this myself on my 997 and noticed an 80%-90% decrease in the amount of brake dust produced with no noticeable difference in performance with street use, even during spirited canyon runs and hard braking going into corners. Coming back to OEM pads, I'm already missing my Hawk pads from my 997. It does not appear that Hawk makes pads for 991 S's from what I can tell. I emailed Hawk to find out if they do make them, or intend to at some point, and have not heard back yet. Does anyone here have any brake pad recommendations that significantly reduces brake dust?
- Oil
I know, I know, it's a hotly contested debate and everyone has a different opinion on what oil to use, but I do geek out on the subject a bit. Having just come from a 997.1 the bore scoring PTSD is real, and used oil analysis was a way of life for many of us. While I realize that the 3.0L engines in the 991.2's are fairly robust, I intend on keeping my car for a while and want to make sure it maintains its reliability. I'll be doing my own oil changes and will likely do used oil analysis at least to start in order to get a baseline. Yes, I've searched here but am not finding many results. That's probably a good thing considering that most people don't even worry about which oil they use as long as it is A40 approved. I'm not looking to start a debate here, but if anyone has any good links here on Rennlist or elsewhere (preferably with UOA results), I'd appreciate it.
Thanks in advance.
- Brake Dust
- Oil
Thanks in advance.
Climate control is inexplicably part of the entry+drive system. As far as saving it as completely "off" I'm not sure, I think you can only save it at minimum speed?
For RAS alignment, these cars are comically easy to align. I can't stress how simple, basic, and straightforward alignment is on the non-GT 991. $120-180 is reasonable around here for a four-wheel, as it's only a 45 minute process. Unless you're replacing a RAS motor, which have a very low failure rate, the fact that it exists has no bearing on the complexity of the alignment.
There are lots and lots of threads about brake pads, rotors, and dust. I always just ran OEM and just washed the car semi-regularly so I don't have much of an opinion or advice here, but there are a handful of preferred options to reduce dust and maintain most of the stopping power.
Oil. Please let's not make this yet another oil thread. Any approved oil in any remotely close to approved weight changed at an interval that can be described as "regular" will be just fine.
asellus (05-25-2024)
Hawk yellow box ceramic pads for the 991.2S:
https://www.zeckhausen.com/catalog/p...c8rcbjudd3f0o5
I noticed exponentially less dust compared to factory pads.
When my 2017 C2S with RAS was last aligned, the tech said the only nuance with the RAS was that the ignition needed to be on when he aligned the rear.
Welcome to your 991. If you would like the tech sales manual, PM me with your email.
