Any Way To Temp Disable the Car While I'm Away
Urban myth. I tried it for kicks decades ago when I stopped using the club, it doesn’t work. I’ve heard dry ice can do it, but who carries that around? BTW I don’t actually use this anymore, just a relic from my university days when I used to park on the streets of East Baltimore in the 90s. Now I’m not even sure a car thief would know what it is, so it might not be a very good deterrent after all
Received 1,679 Likes
Pull the fuel pump fuse.
The following 2 users liked this post by Indyxc:
carlosluis32 (05-27-2024),
Pieters (05-27-2024)
What is the threat? Is it parked in public (no security)?
Is it in a private garage in single family home?
Condo parking or multi housing garage with low security?
If in your private garage - physically lock the garage door from the inside. That prevents someone electronically opening the door by hacking the garage door signal.
You can also set up cameras/surveillance relatively inexpensively that you may monitor from your phone or remote device. As long as the camera is good quality, and has infra-red capability, or the lighting is good - you can capture photos of anyone attempting anything with your car. Of course if their faces are covered it may not be too helpful, but if you capture images of their vehicle, it might help.
Club easy to defeat:
https://cwbchicago.com/2023/11/how-d...y%20to%20clone.
Brake lock?
V35 model claims to wk on Cayenne & Macan, Will it work on 911?
Brake lock?
oh shoot I forgot the really obvious way to disable your car
take your key with you.
