Strange behavior on MFD Oil Measurement. Sudden major change in reading.
@Jack F
Click on the link in post #6, which provides pictures of the unit (accessible next to the drain plug on the bottom of the oil pan), as well as the installation procedure. Replacing the sensor itself appears to be about as easy as changing the front side marker lights, once the oil pan is drained.
True, but based upon post #13, it appears that the 991.2 part number is identical to the .1. I'd place a heavy bet that it's an identical procedure.
