Mechanical Vacuum Pump
Had my car in for service last fall and have since been fighting the coolant fault warnings. Thus far on two separate instances I found two different vacuum tubes left unconnected. The shop did a sloppy job reassembling my car.
Second time I had to tear back in I made a better effort to check all the reasonably accessed tubes and valves for any other surprises.
I tried to find the vacuum pump itself. I know it’s somewhere on the right rear of the engine but is it even accessible without dropping the engine? Figured if I could just access the vacuum tube directly off that pump I could pull a vacuum with my hand pump there and check the whole system at once.
Would at least give confidence I found all the leaks before buttoning the car back up.
Anyone know how to access this?
Maybe Plenum's documentations can help in your journey. Lots to good COV diagrams, COV locations.
Porsche COV info and documentation - Thanks Plenum
I’ve often thought about those resonators. Seems to me that are what I would define as “foo-foo.” They aren’t necessary for the mission of the vehicle. Yet they have these issues and of course add cost.
Lots of features on these cars can be classified as frivolous. Time will tell as these cars age and people keep them on the road what aftermarket workarounds will come up. I know that coolant shutoff to block coolant flow in the engine to heat it up faster makes me uncomfortable. That’s just needlessly flirting with the danger of having a roadside overheating problem. That makes my top list of features I may end up defeating.
The bigger failure here is when the whole mechanism fails and allows coolant to leak around and into the mechanism, but you'd need a whole new pump design to work around this, and the newer pumps seem much more robust to this failure.
Shutting the cooling off to the engine it should be fail save if the COV fails. It just wouldn’t actuate the mechanical valve and never shut off coolant.
The mechanical valves then must have spring returns on them to return them to normal position when vacuum is turned off. That’s my concern, an aging spring breaks or something and that mechanical valve fails to open back up. Then you are overheated on the side of the road.
Has anyone actually had the failure you are concerned about? Wouldn't it be easier to just proactively replace the valve at 100K miles than try to bypass it and all the error messages that will cause?
