Don't even know where to begin
So I have a 2017 911 Carrera 4 GTS. All of a sudden I got an Engine too hot pull over now warning. I was close to home so i went home. I waited a half hour. I put some coolant in and i "test drove" to the store just a couple of miles away. I immediately got the warning again! I didn't even go to the store. I turned around, and when I pulled into the garage I took the following video. I really hope someone can access the below link. What the heck would you do next. ( I know I just opened myself up a bit on that one) Any advice would be appreciated.
Thanks!
https://drive.google.com/file/d/1rlC...usp=drive_link
Thanks!
Seth K (02-08-2024)
Thanks!
Thanks!
EXFIB (02-14-2024)
Never said it was at the correct level. I did fail to mention that I also got a "put coolant in immediately" warning. The level was low and it the needle was pinned. Does that help Dr. House?
fsmich (02-13-2024)
Yes Sir. Believe that was the issue. At the dealer now getting same verified. Should be no problem. Dodged a bullet there! Thanks for your response.
Ps. Found it.
fsmich (02-13-2024)
Not sure how I would have done that. You can drive this thing sideways at 140mph and nothing breaks and the car is like "yeah? that's all you got?" LOL but it's at the dealer. I'll be happy to report back here after I get word. I hope the fricken pump is broken though at least at this point or i'm going to be paying for the whole take down / put back together and then all the funny crack jokes I'm thinking in my head right now but not typing out of respect for this magnificent vehicle aren't going to be nearly as funny anymore. :-)
Seth K (02-14-2024)
You don't crack the reservoir by doing anything, the reservoir cracks from the heat cool cycles.
I had a coolant loss issue on a 997 I had that was only apparent when hot and didn't leak when parked up.
Pressure test on the system showed it leaking from a crack in the plastic. Warranty replacement.
Does not explain that river of coolant you have there though.
Like the other person replying, I can't play the video and your original post suggested it was an overheat without fluid loss.
IXLR8 (02-14-2024)
