Carrera T: explain this! (???)
#31
What speed are the MPG tests done? The T rear spoiler is at a higher angle when deployed = more drag and lower MPG. The T has the S gearing as well with a mech LSD (more robust than eLSD adds small amount of drivetrain drag). All of those combined can easily reduce MPG but especially the spoiler angle.
SpeedCircuit (01-28-2024)
#33
The base model car comes with 19 in wheels and tires and the T comes with 20 in wheels and tires therefore affecting the rear final drive ratio. So for example the 20 in wheel and tire combo is going to have a higher numbered rear gear ratio to offset the taller tire/ rim setup and the 19 in setup will have the lowered rear gear ratio.
Bud Taylor (01-30-2024)
#34
Three things
Different gear ratios on T
More aggressive aero on T with more drag
Base model without optional wheels came with more narrow and fuel efficient 295/35/19 and 235/40/19 tires verses T on wider 305/30/20 and 245/35/20
#36
Oh yeah, the tire width will have significant impact. I think stickier rubber too. On a previous car, I went from medium sticky 215 wide front tires (245 rears) to very sticky 245 wide front tires and rear tires. Highway mileage dropped from about 29mpg to 25mpg.
