After Market Back Up Camera ?
I have the same issue, and would love having a back up camera in my 2012 Carrera.
Seems the oem PCM radio unit is integrated with dash functions. So my original thought of replacing the factory head unit with an aftermarket unit capable of supporting a back up camera went out the window ( as I do not want to lose the integration aspects). Seems other people have successfully installed "Apple Play" devices tied into the orginal factory PCM unit to get back up camera capability ( check out the posts on this in this forum). This seems like a good option.
Here are several options: There is the central mount camera where drilling into the rear bumper is required. If you are planning to use this style, more than likely will be required to remove the rear bumper. Composite wire must be fished from (PCM) to rear bumper.
The other choice is the license plate light insert. This requires you remove the (left) or driver side rear license plate light which is a plug in functioning light and power supply for the rear camera has a positive + red wire, yellow is the video trigger wire and black for ground. You are still required to fish the composite wire from the (PCM) to the rear and connect a trigger wire.
https://www.nmautomotive.co.uk/cameras
The other choice is the license plate light insert. This requires you remove the (left) or driver side rear license plate light which is a plug in functioning light and power supply for the rear camera. You are still required to fish the composite wire from the (PCM) to the rear and connect a trigger wire.
Will this also work on a 2012 911 ( 991.) Carrera? Will that model PCM support a rear camera for display?
The pyramid type camera will work on PCM 3.0 & 3.1 as stated in the link with their CarPlay Kit.
