Backup Camera Help
Backup Camera Help
Hi - I recently purchased a 2013 4S CPO with 23,000 miles. The prior owner installed a backup a camera, which the selling dealer appears to have disabled to CPO the vehicle. Unfortunately, I have not had much luck in getting info from the dealer on what, if anything they did to the camera.
When I put the car in reverse the PCM screen will "blink" as if it's trying to turn the camera on. I am hoping that the dealer did not just cut a wire somewhere. I started investigating, I pulled the PCM and did not see any unplugged wires behind the PCM. I am not sure where to look next. Any ideas?
Thanks!
Thanks!
Thanks!
Thanks!
Before removing the bumper, try removing the taillights. Easy DIY with a torx screw driver. Usually after market back up cameras get their power from one of the wires of the tailights. Try to look if there's traces of a wire that was added. When I installed my backup camera I added a wire in T.
fted (12-10-2023)
Thanks!
Thanks!
Look for a composite wire (black) about 1/8” diameter in which there are three (X3) separate wires (Black, Red, Yellow) likely 18 - 22 gauge in size incased in the black wire. This wire will run from the rear bumper to the PCM. Most logical place to fish the wire is down the center console behind the rear seats and out the rear firewall on either left or right side.
I pulled the taillights and found the connection on the drivers side. There is a black wire that is wired into the taillight and appears to still be connected to the camera. The wire seems to run along the drivers side. Before I pull the PCM again, is there a "brain box" somewhere that I should be looking for? Suggestions on where to look next before pulling the PCM?
Thank you!
Thank you!
Can you ask the previous owner the vendor of aftermarket camera solution they had installed?
Then you can look at install instructions / videos online and figure out if there is an external interface box (navtv, +many others,) connected to the pcm, or if there is a board installed inside the pcm (isudar, + many others).
Or, do a search on "backup camera" on this forum and entertain yourself for hours reading at least 10 threads on backup cameras. I'm not sure if the link will work,
991 backup camera search results
Thank you!
Thank you!
The dealer tech does not remember what he did to disable the camera, he only remembers that he disabled it.
I pulled the PCM again this morning and did not find anything disconnected or an additional box behind the PCM. Here a couple of pictures of the back of the PCM. The only splice that I think might not be factory is the one in the second picture where a black wire appears to have been added to the group of colored wires.
I was finally able to pull back the carpet and I found some type of control box. I have reached out to AV Electronic via email and phone, so far nothing. Not much on their website. Anyone happen to have any idea what this is or does?
Car-solutions interface
The web site has an installation manual you can look at to reverse engineer what you have installed.
Download manual
From my quick review I also see the little black box in the photo as part of the power cable shown in the install manual. It appears there is a board installed inside the pcm.
Use this info at your own risk. It's just what I could find searching the internet matching the interface box of your installation. It shows the backup camera connection and dip switch setting. Look at the easy stuff first, power, ground, connections.
DId you get the remote control?
Good luck, I hope this helps.
