how to code start-stop default to OFF using a piwis 2?
Does anybody know how to configure this with a piwis2? 2017 991.2 turbo s. I think the 991.1 don’t have this issue with ***, as the default on startup is off.
Hopefully, this will help someone else who has a 991.2 and wants to have *** default to off when the car is started, and never have to press the button again to disable it.
OK, I figured this out, but had to brush up on my German . See accompanying photos:
1. You must configure the settings to E, engineering mode which will only be in German. Select E Select BKE Select Codierung Select first field Scroll down and select the two highlighted fields, then next Under Wert, select last mode and ja, now select F8…esc, done!
