Loud lifters ticking at cold start, is this normal?
Old 09-07-2023, 01:08 PM
mikescayenne
mikescayenne's Avatar
Default Loud lifters ticking at cold start, is this normal?
Hello All,
im looking to purchase this 2012.5 911 Carrera S, and upon cold start, it was ticking LOUD, is this normal for it to be this loud, or do you think it may have bore scoring? Mileage is 93k.
Old 09-07-2023, 01:12 PM
neanicu
neanicu's Avatar
Doesn't sound normal to me. The Direct Injection fuel injectors can be pretty loud on these cars,but I can't say for sure whether that's your noise or not...
Bore scoring has to do with the scoring of each piston's sleeve. The scoring would allow oil going past the rings and loss of compression,I don't see how that would have anything to do with noisy lifters...
Old 09-07-2023, 01:24 PM
mikescayenne
here is another video, its so loud. im thinking id need a camera to look in the cylinders before making this purchase...
Old 09-07-2023, 01:37 PM
spyderbret
spyderbret's Avatar
Yeah, that's pretty loud. I would be concerned....
Old 09-07-2023, 02:03 PM
mikescayenne
it is inside a showroom too, so that may exacerbate the sound a little, i asked the salesman to let it warm up and send me another video of it idling when warm. But im thinking ill need to have a PPI done now at the dealer, and ask for pictures inside each cylinder.
Old 09-07-2023, 02:04 PM
asellus
asellus's Avatar
Received 2,117 Likes on 1,320 Posts
tl;dr, sounds like a car that hasn't been driven for a while. Take it for a test drive, flog it a bit, then come back a day later. It probably won't tick when it starts then.
Sounds like lifter tick. That's unrelated to bore scoring. The lifters are hydraulic and one or more are failing to pump up in time -- usually this is caused by poor oil change intervals or low quality oil. Regular oil changes and regular driving will actually fix this over time.
If the car has been sitting for a while and the oil has drained out of the lifter, this can persist on a cold start for a while. My 991 sat for a month or so one time and it did this, but it cleared up by the time I was a few blocks away from my house. My e39 M5 would do this every time it was undriven for more than a few weeks and would take up to 15 minutes to rectify itself.
It's technically damaging to the engine, in that your lifters are slapping the valve stem and slowly, microscopically mushrooming it, creating higher clearance. This clearance is accommodated by the hydraulic mechanism though, so once it pumps up it's like it never really happened. The damage is so miniscule, though, that I wouldn't worry about it. As long as it goes away once it gets up to temperature and doesn't come back after sitting for 8 hours, at least.
Old 09-07-2023, 02:15 PM
neanicu
neanicu's Avatar
But then again let's check for bore scoring because Rennlist said these cars suffer of bore scoring. Are you sure it's not bore scoring?
SilverSFR (09-07-2023)
asellus
asellus's Avatar
oh shoot, how could I forget
Old 09-07-2023, 02:43 PM
IXLR8
IXLR8's Avatar
Originally Posted by mikescayenne
...and ask for pictures inside each cylinder.
And from what I have read, it is not done through the spark plug holes but from the inside after the oil pan is removed. The PCA did a 4-parts series on YouTube about bore scoring.
Old 09-07-2023, 02:48 PM
desmotesta
desmotesta's Avatar
Received 2,063 Likes on 975 Posts
Agree with all of the above
The ticking noise in itself can be alarming but can easily be from stuck lifter/s due to sitting for extended periods of time.
Take it out for a test drive. If, after 10-15 of normal driving, the noise doesn't go away.. you should just walk..
If noise goes away.. Demand Bore Scoping pictures. The burden of proof is on them, they have a shop with Trained Techs. they want to sell this car bad enough (in a rapidly softening market), they should do te extra effort to make you comfortable
Good luck
Old 09-07-2023, 02:58 PM
mikescayenne
thanks everyone for your feedback, they sent me another video after it was warmed up and it sounds much better! let me know what you think
Old 09-07-2023, 03:01 PM
mikescayenne
and another one...
Old 09-07-2023, 03:22 PM
RP4S911
RP4S911's Avatar
Normal. I start mine up to drive maybe once every 1-2weeks. Sounds like that, and does not change if left idle (which you shouldn't). Once you drive it, it goes away. Oil needs to get thrown all over with the rpms.
Edit: 991.1 with 19k miles
Old 09-07-2023, 03:27 PM
desmotesta
desmotesta's Avatar
great, now we know its most probably lifters. Still need to get Bore scoping done before a deal .. or do your own due diligence and have it done at an independent place
Old 09-07-2023, 03:36 PM
neanicu
neanicu's Avatar
AGAIN,bore scoring HAS NOTHING TO DO with the OP's initial question,nothing! Should bore scoring be part of a thorough PPI? Yes! So should checks about a past accident,oil/coolant leaks,condition of tires/brakes,spoiler broken springs etc. The 991 is a pretty solid car IMO...
desmotesta (09-07-2023)
Quick Reply: Loud lifters ticking at cold start, is this normal?
