door sill switch
Just received my DB carbon order and I'm already stuck
. I installed the passenger door sill no problem. I'm working on the drivers side and I cannot remove the switch from the sill. I've viewed the MCarbon instructions which basically says install trim tool and push up - this does NOT work! The control switch will not budge and I'm close to damaging the door sill and switch if I push any harder.
Any ideas???
. I installed the passenger door sill no problem. I'm working on the drivers side and I cannot remove the switch from the sill. I've viewed the MCarbon instructions which basically says install trim tool and push up - this does NOT work! The control switch will not budge and I'm close to damaging the door sill and switch if I push any harder. Any ideas???
Any ideas???
. I installed the passenger door sill no problem. I'm working on the drivers side and I cannot remove the switch from the sill. I've viewed the MCarbon instructions which basically says install trim tool and push up - this does NOT work! The control switch will not budge and I'm close to damaging the door sill and switch if I push any harder.Any ideas???
I also assume you have already pulled the door sill off from the car. I also pushed from underneath while using two tools & it popped out. It was a pain though.
