Door hinge
Old 07-23-2023, 01:59 PM
Holger B
Holger B's Avatar
Default Door hinge
Driver's side door making some noise when opening all the way. Is there a procedure for lubricating the hinge and what's best to use for that? Thanks.
Old 07-23-2023, 09:21 PM
payamfsu
payamfsu's Avatar
mine does as well, what year is your car ? I was going to let the dealer know since car is still under CPO.
Old 07-24-2023, 12:14 AM
BotterBuilder
BotterBuilder's Avatar
Wouldn't surprise me if they said thats 'cosmetic' and wont replace the door guide.
They're cheap anyway. I just bought two a few minutes ago on Suncoast for $41/each.
Old 07-24-2023, 02:11 AM
BlitzIS
BlitzIS's Avatar
I spray silicone lubricating spray around and inside the hinge area. It helps quiet down the door noise when opening and closing.
Old 07-24-2023, 02:24 AM
Holger B
Holger B's Avatar
Mine is a 2017 and it's likely the door guide. Not sure that I'm up to taking the panel off to replace it. Probably just lubricate it for now.
Old 07-24-2023, 08:45 AM
F355bob
F355bob's Avatar
Use Boeshield T-9 lube spray. I did mine 3 yrs ago and never made noise again and it was really bad.. Made by Boeing to use on their planes and by far the best lube made.
It will last and not wash off with water.
Old 07-24-2023, 08:02 PM
straka
straka's Avatar
I believe there is a Porsche replacement lever door hinge made for replacing squeaking door hinges on 991s. I think I saw it at Suncoast Porsche. I recall it was a plastic/composite material rather than metal. I'll stay with the original metal hinges, periodically lubricating them.
Old 07-25-2023, 01:48 PM
koala
koala's Avatar
It is probably the check straps. I replaced both of them a couple of years ago and since then it has been 100% perfect. There was no amount of lubrication that could solve the problem.
It's an extremely easy, DIY-friendly swap.
Old 07-25-2023, 01:55 PM
CSK 911 C4S
CSK 911 C4S's Avatar
I need to do the 2017 as well.
When my 2013 doors did this they just lubed them up with what looked like white lithium grease and they never made a noise since.
Old 07-25-2023, 02:01 PM
cbredesen
cbredesen's Avatar
I didn't know that's what they're called but I do recall someone in another thread (maybe the bug rattle/creak thread?) noted with a picture that these are noisy as hell. Mine are making a racket on my 2018 and I was just looking for a DIY on YT but came up short. If there's a guide somewhere I'd surely read/watch and do this myself! Lube is not making the sound go away.
Old 07-25-2023, 02:09 PM
cbredesen
cbredesen's Avatar
Related thread (can mods combine?)
https://rennlist.com/forums/991/9579...-or-fix-2.html
Old 08-12-2023, 01:14 PM
payamfsu
payamfsu's Avatar
check straps? can you post an image?
Old 08-13-2023, 01:53 AM
t1gerb0y
t1gerb0y's Avatar
This?
https://www.suncoastparts.com/product/SKU9X1GUIDE.html
The following 3 users liked this post by t1gerb0y:
cbredesen (08-13-2023), duxsi (08-24-2023), koala (08-13-2023)
Old 08-13-2023, 02:14 AM
jdgamble
jdgamble's Avatar
Had the same. I sprayed inside the door panel around the guide, and it did nothing. So I sprayed the hinge bolt, and whisper quiet now. White lithium grease.
Old 08-13-2023, 11:36 AM
Tier1Terrier
Tier1Terrier's Avatar
Originally Posted by t1gerb0y
I was wondering the same. I also wonder at what point in time did Porsche stop using the old door guide and begin using this new one?? Seems like a fairly inexpensive part to pick up 'just in case' the noise starts happening.
Quick Reply: Door hinge
