Sport PASM Retrofit?
Hi all,
I installed the sport front lip spoiler today on my 991.1S and did notice a difference in cornering at higher speeds. Got me wondering if I should reduce the ride height by another 10mm and adjust the rear wing as per the Sport PASM option.
Is this something I can buy parts for or have an OPC do for me?
The following 3 users liked this post by MingusDew:
timothymoffat (11-29-2023)
I haven't found anything that confirms SPASM equipped cars have spoilers coded for different deployment versus the rest. I believe they all function the same. The sport design rear spoiler is actually programmed to deploy less due to the extension/additional length.
@le_gazman assuming you're talking about swapping from the base front lip to the sport, if you felt that, I am impressed....about to take mine off and go for a drive to see if I feel it
I only test drove it afterwards to make sure it wasn’t going to fall off!
I just picked up a 991.1 C2S. After replacing tires, getting alignment done, etc etc I took it on its maiden highway run and I feel like the front is bit more floaty at speed than my old carrera 4 - which is entirely understandable given this car is RWD.
Question for you folks - do you think this SPASM front lip would improve downforce on the front to help with that ?
roadsession (11-28-2023)
I believe they're describing the difference from stock in which case yes you have both springs and variable shocks. To my knowledge, the only difference between PASM and S-PASM is 10mm height and a bit of stiffness. I have not seen official measurements or specs but that's what I gather and I'm happy to be corrected by someone who is more informed!
