(Urgent) 991.2 overheating
Hi guys,
I am new to the forum, and unfortunately, I have an urgent problem.
I have a 2018 991.2 Carrera Cabriolet.
Three weeks ago I was driving through the town and suddenly noticed that the water temperature was 120c. The car gave me the notice to immediately turn off the vehicle to cool down. Later, I double-checked the coolant water, it was at maximum.
I was driving a couple of times more, before going to service and the temperature was stuck at 90c (the middle).
On Wednesday, I had a service performed, and they said they have changed the water pump. By the way, they told me that, I got the feeling that they had absolutely no idea what was wrong with the car. This morning, the same happened. The temperature went to 120c and I had to turn off the car. The car was off for 20 minutes and it worked perfectly later. I am not sure, but I believe that both time the car overheated I was in Sport mode. But I am not 100% sure.
Does anyone have any idea what could be the reason behind all this?
Thanks a lot,
Ivan
Thanks a lot,
Ivan
probably a COV failure, that's fairly common on these cars.
the water pump would physically leak.
with regards to the "staying at 90c" -- the gauge is programmed to display 90c when the coolant is anywhere between some pretty huge range -- 80.3c to 110.3c. I have a writeup on how to fix this.
Could maybe also be a defective thermometer, although I have no idea if that can be an issue on a 911. I had this issue on an Audi S4, it would say the car was overheating but it wasn't, the thermometer was not working properly and had to be replaced.
Actually, if there is an air bubble, he could simply remove the coolant reservoir cap..... start it up and let it run a bit. That should burp out any air that might be trapped in the coolant system. Matt Armstrong did that in his GT3 build, when it kept overheating. Granted different engine, but the principal holds up.
Watson (06-02-2023)
FYI, 991.2 motors don't have COV's. That was a 991.1 issue. It sounds like there may be trapped air in the system. The cooling lines are very long and the radiators are fairly large so it can be difficult to bleed the system. See if your coolant needs to be topped up, otherwise, take back to the dealer.
Also, It's not as simple as just opening the coolant cap while running to burp the engine. They really need to be vacuum filled.
Matt did the vacuum fill method quite a few times using the right tool, and it still had the air bubble. Then he raised the rear of the car to make the air pocket rise in the system, took off the cap, started it and the air pocket burped out. I think it was in video 4 or 5 of his series on the GT3. At times, simple solutions do work.
sletcher (06-03-2023)
