Random popping noise from engine bay
Old May 19, 2023 | 05:56 PM
ThePhanatic's Avatar
ThePhanatic
Default Random popping noise from engine bay
While I wait for my friend to bring my OBD-II scanner back to me this afternoon I figured I should make a post to see if anyone has any ideas on what this may be. I hear this random thud / pop sound when the car is running. I've driven it around and gotten it up to temperature and filled it with gas, but in both cases the issue persists.
File Type: mov
Old May 20, 2023 | 12:39 PM
ECM's Avatar
ECM
To me in sounds like a flap or something not holding. There is a flap on the air intake box that opens into a resonator. When driving, does the intake sound change pitch each time it pops? When working on my car a while back, I removed the air intake and the flap was broken. When I propped it open and closed it by hand, it sounded very similar.
Old May 21, 2023 | 04:00 PM
ThePhanatic
Doesn’t really change no. I checked misfires and there were 36 after a 20 minute drive so I’m thinking either spark plugs (which are due) or cleaning the throttle body which hasn’t been done.
Old May 24, 2023 | 11:38 PM
ECM's Avatar
ECM
That makes sense. Did all 36 misfires occur during the previous drive? On my scanner, the misfire count is for the last ten starts.
Old May 30, 2023 | 01:52 PM
ThePhanatic
I believe they're from each start as I've seen the numbers go down when I did a few drives to test around. Car is awaiting service now but David Modderman seemed to back what was suggested to me by Alex at Sharkwerks: plugs, coils, clean throttle body first. My biggest concern is that it's bore scoring, even though I know that's logically not common in the DFI engines and the misfire count is incredibly low at the moment (less than 1 misfire per minute).
