Rennstand or Jackpoint Jack Stands?
I want to purchase a pair of jack stands for my 2017 991.2. After searching it appears that the two most popular are the Rennstand and Jackpoint brands. Any feedback on these stands? They are priced nearly the same. I've been placed on a waitlist for the Jackpoint brand and I don't know for how long. The Rennstands appear to be available.
Jackpoint stands are strong and very sturdy but they aren’t very tall. They are good for brake work and oil changes (for most cars). Rennstands have height adjustment (upto 16.5 inches)
Winnetka (01-28-2024)
Jack Point Stands
Mark
I'm a huge fan of my Jackpoint stands. They work really well and are simple to use. I have no experience with the others you mention so I can't compare, but just wanted to say you wouldn't go wrong w/ Jackpoint IMO.
Porsche_nuts (05-15-2023)
I was ready to get rid of my Jackpoints because I bought Quick Jacks. Recently, was short on time and had to lift car quickly. Taking out the Quick Jacks, connecting, repositioning, etc, just did not have time. Let along breaking everything back down and storing again afterwards. So got out the old jack under the cross member then fitted the Jackpoints underneath. Took about10 minutes.
I use these, they are great and very sturdy.
https://www.pelicanparts.com/More_Info/TOL104981.htm
I've had a set of RennStands briefly, and I found them not to be as stable as Jackpoint stands especially during raising and lowering the car.
When you raise a single corner, the car goes into a significant tilt (both side-to-side and front-to-back) and I wasn't comfortable with a tilted car landing on the RennStands.
This tilt is more significant when you set a taller height on the RennStand. I saw the stand slip a couple of times and was very scared.
The safer approach is to use 2 floor jacks and raise both sides of the car and reduce the side-to-side tilt of the car.
Very quickly I moved to using Jackpoint stands and while you still require some minor adjustments as you raise/lower the car onto them - it's nowhere as nerve-racking as RennStands.
Since then I've also gotten a QuickJack and I pick QJ vs Jackpoint depending on the job.
I "store" my QJ on the floor under the car, so positioning it and connecting the hoses is not very significant work - but still for smaller jobs I prefer the Jackpoint stands.
