New Battery
BTW, I would not buy a battery from Porsche or any manufacturer either as they are at least 50% more expensive.
But lets look at your problem/solutions first. You state you do not have a place to plug in for keep your car charged while out of town...
-First thing issue is to check is why you car is draining dead in a week, that usually indicates a bad battery or a high parasitic drain on a good battery. So first check your battery's condition at a local Autoparts store and see if it passes load tests, if its not that then you probably have a high parasitic drain causing it to drain the battery that fast. You should be getting about 3-4 weeks out of a fully charged stock Lead/Acid Battery in good condition in 991 provided you don't have extra accessories like Cameras, Radar detector USB Connectors or things like that. So do those checks first. You can find how to check for parastic drains on Youtube.
- If you travel and are away from your car and do not have power to plug in a charger the simplest way to deal with this to get you through additional time is to have another battery and just connect it in parallel to your existing battery, that will give your car basically twice the capacity (provided you use the same size battery) while you are on the Trip out of town and will easily last and extra few weeks if not longer... again this depends on your level of parasitic drain. But by doing this you don't need a charger during these periods, you are just upping your capacity so your car won't run down. Of course its sort of a hassle but easy with a set of alligator clips or cheap jump starter cables. Just positive to positive , Neg to negative and the batteries will basically just act as a battery larger battery during storage.
Now to talk about Antigravity Lithium vs Lead..
-The questions is not if its a better battery, it is hands down a better battery....the question is it a better value to you as an individual in your application. So that will depend on what you value in features and benefits vs the cost. So if you value the following then you would want to consider buying one.
- Built in Jump Starting so you will never be stranded. If you every drain your Antigravity battery dead accidentally you won't be stuck or having to mess around with a Jump Starter, Jumper Cable and you won't have to mess around with trying to get into the frunk through the fuse panel like you do with a Lead/Acid Battery. You won't have to look at, or touch the battery, and if it was raining you don't have to get wet or mess around. You simply press one of the two provided keyfobs start the car and drive off. If you have a wife that drives the car and the battery get drained you don't have to explain about how to jump start a car... just say press the keyfob and start the Car, no knowledge required. Thats a massive benefit no matter how you slice it.
-Longer life than lead/acid Batteries.... there is two reasons for this. The first is because you can't damage the Antigravity Lithium Battery easily like you can a Lead/Acid battery. For example the #1 cause of damaging a Lead/Acid Battery is accidentally over-discharging it. Everyone has had this scenario... you come back to a dead battery because the lights were left on, or you stored it to long and the car drained it, or you left the stereo playing while you cleaned it. So if the battery goes below 8v is starts getting damaged, and the longer its left like that the larger the damage. That damage results in dramatically reduced life, the battery won't hold a charge , and it looses alot of its power. This can't happen with our battery because it has built-in protections against OVer -Discharge. So it can't be damaged by accidentally leave it with the lights on, and it has many other protections such as short-circuit protections over-charge, over current and more. Secondly Lithium is rated at 3000 cycles... the best in lead acid is rated at about 1000 cycles. A Cycle is a full discharge and recharge of a battery... So these are Labs that show this not Antigraity.... its just and inhearant attribute to Lithium over-lead acid. So the life span will be dramatically better due to these factors.
- The lightwieght factor is a "cool" factor but is more relvant for the Performance oriented and Track guys. I rate this below the other factors that make Lithium better than Lead/Acid... its cool, but I would rather have the longer life and built-in Jump Starting since they are extremely beneficial...
So is the Cost worth it overall? Well when you wiegh the longer lifespan you will find that the cost is a wash being you will get a longer life span so the dollar per year of use can actually be lower than with a lead acid battery. But if you factor is the hassle saving features such as the built in jump starting then that get more personal. Many people love the feature and bought the battery for that. Other claim they don't need it. We a few emails a month with someone say they had to use the restart feature and it saved their butt.
What are the Negatives about Lithium...
Its buy-in cost is higher than lead acid batteries
It is not as redily available at every Autozone or Pep Boys.
It is not as good for Outdoor Cars in contantly below 20 degree Ferenhiet conditions... though it has no problem being in 20 degree temps for a week, it just not as good for a Car in MinnisotaColorado snow that is stored outside during the winter. The battery can freeze faster than Lead/Acid, but we have plenty of people in Colorado doing fine through the winters using them in daily driver trucks.
Any questions let us know.
allen986 (03-30-2023)
When you are comparing an 80Ah Antigravity Lithium Battery to and 80Ah Lead/Acid Battery, the 80Ah Lithium Battery will have almost 2x the usable energy. As an example the 80Ah Lithium Battery is roughly equivalent to a 150Ah Lead/Acid Battery. The reason for this is due to the USEABLE ENERGY of these two different battery chemistries. What you are not aware of is that LIthium offers almost two-times the usable energy as a Lead/Acid Battery of equivalent Amp Hours. For example you can only use 1/2 the rated capacity of a Lead/Acid Battery, but with a Lithium Battery you can use about 90% of it rated Capacity. So in essense a 40Ah Antigravity Lithium Battery is roughly equivalent to a 70Ah AGM Battery that comes stock in Porshes with the H6 Battery! Yet, the 40Ah Lithium will also crush the Lead/Acid in Cranking Power and the speed of the Motor turn-over....
YOu can easily fact check my statements on Google... just type in "useable energy of a lead/acid battery"
Anyway, I think people need to understand that because your post is not accurately comparing the realities and made it seem like our battery is $1200 dollar vs $250 dollars in your statement and that is extremely inaccurate because you can't compare Lithium to Lead/Acid when Lithium is giving you twice the useable energy.
Not worth the cost at all IMHO. The OEM AGM battery will last just about as long, be a quarter of the price, and have two or three times the capacity.
Your car has a BMS that will start cutting electrical systems if the voltage drops too low. Having a redundant one in the battery itself is pretty overkill IMHO. Having a battery inside your battery to jump your battery when your battery dies because you didn't plug it in and the measly 24AH capacity it has wasn't enough to last your three week trip out of town is just bordering on insanity.
Anyway, in no way am I saying its for everyone, all purchases are a personal choice, but you statements always seem to have inaccuracies like saying its a 24Ah Battery,when we offer it in many different Amp Hour options, and also bringing up that everyone should be keeping their battery on Chargers. Well, the fact is alot of the times a dead battery happens far away from home, or outside of a spot where you can easily find a Jump, yet with our battery it won't matter where you are.... you will get the start and get out of that dead battery emergncy, and if you even do it once or twice and you value your time it pays for itself in eliminating that hassle...
I do not have a battery issue, so why do I need a grossly overpriced AntiGravity battery? And if I did have a battery issue, I'd fix the issue and still continue to use an AGM battery as before.
If you claim I can get 3x the life from your battery I bet you I cannot get 48 years out of one of your batteries considering I already got 16 out of a conventional \flooded lead acid battery.
And the last thing I need is a lighter battery out front to further upset an already tail heavy car.
Jeez, I got to put up with you on ADVRider and here too. Give me a bridge to jump off of.
asellus (03-30-2023)
New Battery
First I would like to thank everyone for their input about which battery I should buy. With such diverse opinions I'm more confused now then before, so I’ve decided to spend $851.37 including shipping for the Antigravity battery. I will see what happens once I install it. It's only money right?
Thanks again for helping me make up my mind.
koala (03-30-2023)
Bud, I do not need more usable energy. The Original and Stock H7 Banner battery that came in my GTS works perfectly well in my car after 8 long and full years in service and I'll probably get many more years. And if not, I'll just spend $250 and get another one like it that'll last that long again. And if they work in my car, then they must work in every other car out there.
Not to bag on Antigravity as I'm sure there's a niche market where they do make sense, but if something costs 4 times as much then a seller has convince us why it's at least 4x as good. Lighter I get for the track guys, but to most of us it's not much of a selling point. Longer life is good, but is it 4x longer? Not from what I can tell. Twice the useable energy means nothing to me when my battery cranks over just fine and has done so for years. 3000 vs. 1000 cycles is also meaningless as who lets their battery fully discharge that much? 1000 cycles over five years would mean I fully discharge my battery every other day. No one does that. As to the once every three or four years I actually need to jump start a car, I can by a jump pack for $100 if I'm worried about that.
Again, not to just go after Antigravity as every Porsche aftermarket vendor plays this same game. They all know many high-end car owners have more money than sense, plus we are all so used to paying the Porsche/Ferrari/Lamborghini tax that the vendors think they should get it too. But unless you are in a very special situation (e.g. a highly competitive tracker where the weight is critical) it just doesn't make financial sense IMO.
And the pure BS advertizing on their sites aimed at people that know zilch about batteries such as "Low Self-Discharge" as advertized on the "benefits page". That applies to any battery that is not connected to anything such as a battery sitting on a store shelf. Unfortunately, our batteries are connected to something called a vehicle. AGM batteries also have a very low self-discharge....when not connected to anything, but who cares.
BTW, I just looked up the H7 AGM on Walmart, $170. Tough to beat, but I will likely go for an East Penn battery as I have in the past.
Look, I could go on but why rain on his parade.
Not frugal, just smart. Why would I pay more for a "specialized" battery that gives me or anyone in the real world no added benefit. My factory battery starts all my vehicles every time, I get long battery life and the list goes on. So why pay a penny more. And if owners need to replace a battery every couple of years, its probably not the battery but the owner.
My work takes me out of town once a month for a week or more.
