Anyone that is interested in getting this exhaust from top speed pro 1 know that your factory rectangular tips will NOT fit back on. I need to get the quad tips that are on models with PSE or I’m assuming from any carrera S? Here is what my exhaust outlets look like now until I figure out what tips to buy.
Hey all, wanted to come and show you the final product. Massive thank you to @Silversun262 for saving the day with the PSE tips. We adjusted the side mufflers and got it all hooked up, but one last issue… it looks like it’s hanging low but there were no more adjustments that could be made to lift anything. So I was thinking about when I went on suncoast to see how much it was to order PSE, there was a bubble that stated “if you have base carrera additional hardware is needed for PSE install”. I wonder if that is what makes the fitment correct? Anyways we will try playing with it again to see if we can maybe angle it up a little so it fills up some of the space without looking like it’s pointing up. Up close, you can really see how low the exhaust is hanging here. Looks better from farther away
I just did the Top Speed Pro-1 valved exhaust. Very happy with it. If you don't hook up the valves then it is open/loud mode.
Quality was great and install was pretty straight forward and easy. https://youtu.be/8IGVgV4pWhs
@Catharpin Quick question, since the topspeed valves are further apart then the PSE ones what is used to tie the 2 valves together? Do you use a new vacuum line between them?
