Heat/Heated Seats Not Working in .1 4S
I have a 2014 4S. The heated seat button flashes on and then turns off immediately. The heat will blow cold air whether it’s 35° or 55° unless the temperature is set to 73°. Has anyone else experienced this? Is it a thermostat issue? Could the seat problem be a result of the battery? AC worked fine over the summer
Two separate issues.
HVAC heat is a coolant issue - COV is likely.
The on-then-off is usually a fuse issue with the seat in question. Sometimes the connector under the seat, visible from the rear of the seat, cracks or gets unplugged. Most of the time it's the fuse. Most of the time people check the wrong fuse, too. Each seat has its own fuse, check the kick panel fuse box on the appropriate side for blown fuses.
