PDK Clutch
PDK Clutch
Hello Gents,
I am trying to better understand the dual clutch system in my 2013 991.1 , I have PDK and I wanted to know if it's true that when if you drive in auto mode the clutch would wear out faster vs.manual shifting. I know when I ma driving in auto by the time I hot 50 miles the gear is already in the 6th gear, where in manual mode I have more control on the shifting where I wouldn't be exercising the clutch as much. I like driving the car with both options I was just curious how much of a wear do you see in auto mode over time.
Thank you
Thank you
Never ever heard anyone express any concern about this. The PDK is pretty much bullet proof (with a very, very few exceptions) and does not require much anything other than the basic service that has very very long service intervals (first one for 991.1 at 120K miles or 10 years if I recall correctly) . While not a mechanical expert to any extent, that just sounds a complete non issue.
I think the powertrain would wear out around the same time as the PDK.... I mean they throw this transmission in everything from Panamera's to their SUV's
This isnt a Ferrari F1 transmission
uphoto (01-31-2023)
Thank you gents. for the inputs, I guess my understanding was since it's a dual Trans. it has two clutches? or is it designed as one? which was my initial concern about the clutch wear. I be honest with you I like to drive it in manual mode and I tend to down shift often which definitely contributes to the clutch wear.
Cheers
Cheers
Cheers
Cheers
detansinn (04-11-2023)
Good morning
Thank you Chuckbdc, and other's for sharing the information. I have a better understanding now. Since we are on the topic of PDK, as I had mentioned in the beginning of the tread my 991.1 is a 2013 with 20k miles, I know the service recommendation is 120k or 10 years, well I am in the 10th year now. Has anyone had a PDK service done? what is a typical service cost? Can a Porsche Indy specialist do the service or it has be done by the stealer-ship?
Cheers
FM
Cheers
FM
It’s kinda of a life-time tranny unless it blows up. So preserving one way or another is mute. I’d simply enjoy and not overthink it.
Good morning
Cheers
FM
Cheers
FM
It's not really a flush as the clutch fluid is simply drained and refilled, only about 60% of the fluid is actually replaced as large amounts are trapped in areas that don't drain. I DIY'ed mine at 60k/10 years (997.2) and the drained fluid looked brand new. I'm sure I could have left it another 60k miles and it would have made no difference.
Multiple examples of people getting screwed over the by dealership as they charge ridiculous prices for the fluid (up to $60/liter, more than 2x the online cost) and charge for a dry fill (5+ liters) instead of what was actually drained.
Izzy911 (04-15-2023)
I'm pretty certain that the only point where the PDK could get more "wear" than not in any way is if it's in stop&go traffic it's entire life. They say it's better for the car to give it more room in traffic to let 1st gear engage fully when moving up. Either way, as odd as it is, the very very few PDK issues have been random and usually by people that baby it either way. Nevertheless it's bulletproof and statistically less issues than any and all transmissions on the market, even with the usual Porsche track day abuse that most other cars never see. It's been the only 3rd pedal-less car i've ever owned that I enjoy this much.
Rather, the better answer is, don't coast = Letting the car roll without using the throttle.
If the car needs to move, use the throttle and feather accordingly.
Letting it coast is not ideal nor recommended.
Stop&Go as in having the car constantly slipping the clutches before engaging first. Like you stated, help it get into first instead of letting it constantly slip. However, this is nitpicking because the PDK is engineered to do all this without problems, but it's the only real wear point I can think of.
