Wide Price Range for Ceramic Coatings
My understanding is that a majority of the fare is for the labor as it can take several hours from start to finish. However, I've received 3 different estimates in the last couple weeks and the vary wildly from company to company. I'm normally the person that avoids the cheapest and the most expensive when soliciting bids for home improvement type projects and will probably follow a similar route here, but was just curious if others had been down this path before and seen pricing all over the map.
Here is a sample of what I'm seeing:
- Shop #1 - Mobile service in my driveway; 2 step paint correction, clay bar, ceramic coating on paint, glass and wheels (2yr) - $350 (current promotion) or $550 for 5yr
- Shop #2 - Offsite facility; 2 step paint correction, clay bar, ceramic coating on paint only (2yr) - $1,150 or $1,550 for 5yr
- Shop #3 - Offsite facility; 1 step paint correction; clay bar, ceramic coating (2yr) on paint and glass (no wheels) - $800 or $1,200 for 5yr
The other 2 are not that far off from each other, price wise. May just come down to what product they use, experience in applying ceramic, and local reviews of each shop.
Once you complete the ceramic, you’ll need to have it away from elements about 1 day or 2 for proper curing.
Which detailer can do the best job on the car forgetting about the wax/sealant/ceramic you put on top?
Depending on the condition of the car, as you said, its all labor. The paint needs to look great before whatever you put on top. The cost of the coating itself is small relative to the labor for the detailing. And the labor to install the coating itself is small.
Detail shops try to break things down into terms that they think people digest easier. Clay, one step correction, eight step correction, one coat, 5 coats, etc. Its all honestly marketing BS. End of the day you want a detailer that will make the car look good and fix whatever issue you have to the best possible outcome without damaging the car, burning the clear, etc. Their price should be based on the condition of the car.
In my experience the ceramic coating really does not help that much with swirl prevention. Its all how the car is washed and handled. With a daily driver I can't say I notice any real coating benefit after about 2 years. Then it needs to be polished and top coated again.
Ceramic coating warranties are again mostly BS.
I like ceramic coating. Its a long lasting hard paint sealant but its far from magic. Where I actually have had best luck with it is on older cars with single stage paint but thats another story.
I see you are looking at 2yr coatings this tells me they are probably not using the “pro” grade products that are usually only available to professional shops. They are most likely using the products that can be bought off the shelf. My recommendation would be go to a higher quality coating. I have used both and there is a big difference. Not at first but I have noticed the 2 year coatings start to fade after 6-9 mo
paint correction, systematic elimination of swirls, water spots, etching, scratches, etc., when done properly and systematically, requires:
1. ample prep after wash/decontamination process -
2. evaluation - what imperfections does the paint need addressed ? this requires excellent lighting and in a controlled setting
3. paint should be measured with ultrasonic paint meter to asses overall health and make sure there’s enough material to achieve desired results of step 2
4. Strategic taping of the trim, plastics, ppf, etc. in preparation to paint correction
5. Only now can the actual paint correction begin. This process alone can take 1/2 day to several days to achieve desired results
6. then a proper wash is necessary to clean the entire vehicle from all the polish dust and residue that’s accumulated in all the seams, door jams, vents, window trim, lettering, etc.
only now is vehicle ready for ceramic application which also requires similar scope and attention
so, hopefully that helps you a little to further prequalify the vendors you’re considering
our industry has become extremely saturated in the last 5 years and the line between the genuine product and “good enough” has been blurred more than ever…buyer beware
hope this helps and let us know how it turns out
The real work, as noted by others, is the paint prep - and usually this is just on the clear coat, right?
Once the paint has been corrected to the desired result, you must consider the ceramic coating being used. The retail coatings are easy to apply but also do not give you the results of the pro coatings when it comes to overall depth, gloss, and protection. The pro coatings are hard to apply as they are thick, and some require infrared lighting and a few weeks of no washing to properly to cure. On top of that a good shop will apply a few coats of ceramic coating not just one, and each coat as to cure to a certain point before its considered complete.
On top of all that, the shop performing the work must be clean and very well lighted to see the imperfections. It also takes some talent and good eye. I technically know what needs to be done but no way can I reach the level of what I have received after it’s been completed by a professional.
It’s a lot of work and can be expensive, but the time saved washing, and the overall look of the car is worth it. Anytime I have gone to sell a car that was properly prepped and coated I got more money for the car even for a trade in. You can also go the cheap route but don’t expect it to look the same or last as long.
If not applied in the proper environment, out of the elements, and allowed to cure properly you can actually make the car look pretty bad with ceramic. It will look smudged permanently among other things and the "warranty" won't cover improperly applied coatings. The product is important, they aren't all the same, so ask what they are each planning to put on your car. Also, depending on the swirl marks you may need more like a 3 or 4 step paint correction with wet sanding and that also takes skill not to damage the paint. You should pay $1500 - $2500 depending. If you don't have PPF on your car that would be a good time to cover the front half while the paint is perfect and then it's protected from rock chips and other stuff that will hit the paint on the road.
